BEST way to remove vinyl paint
I need to remove some vinyl paint from some vinyl door panels and other vinyl parts.
What's the best way to do that? Eastwood says use lacquer thinner...well that does not work too well...what does? Thanks. ric |
Chris
Re: BEST way to remove vinyl paint
Are you sure they are vinyl and have paint on them?
I was going to say thinner also, it works great. Might have to use alot more and really get the area wet with it to soften the paint. if that doesn't rub the color of the paint off on the rag then there's no paint on them or something. Anytime you use thinner you should see the paints color on the rag, unless it's clear, or it's made that color like molded plastics or whatever.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
It'd be alot cooler if you did
I used lacquer thinner on mine.. it wook alot of elbow greese but it did get it done for the most part. It worked best if I let it sit on there for a little bit first.
The Crazy Machanic
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() |
Happy to be here
![]() Join Date: Mar 2000
It took me about an hour per panel to strip these with laquer thinner.
I did the same thing and had the same results. The issue is the parts are really not clean. The pix posted by N2TRUX is a perfect example. Red paint was removed from blue panels leaving a sort of pink cast to the blue panel because the lacquer thinner does not remove all the paint. I'd like to find something that will remove ALL of the paint.
Thanks. ric |
Insert Witty Text Here
You may have to dye them again to get them the right color.
Slonaker |
Chris
Hmm I've always had great luck with thinner, It's always removed everything for me, I might use alot of it and go through a few rags, once they get the paint on them then they'll streak(sp?) and leave trails of the paint your are wiping off on what you rub them againist.
Only other thing I could think of would be aircraft paint stripper or something. I've never had any luck with any paint stripper, I've always ended up sanding the paint off what I could.
best bet would be to redye them again after you strip them. Make sure to use the prep stuff first, then dye. It's the only way you'll get it to look perfect.
I wouldn't recommend aircraft stripper on these - it's too caustic. |
Happy to be here
You will absolutely need to dye them. Mine were totally clean when done, but they did have a dull finish. Here is what they look like now.
Chris
Armor all wouldn't shine them back up?
I would have just dyed them instead of stripping them anyways, but I know it's better to remove the old before putting on new.
yup,when i redid mine the shine came back.
" Never look up a dead dogs butt." ![]() |
