04-11-2007, 01:33 AM | #1 |
70 blazer in ebay 2wd but it had leaf springs in rear
anybody see the question and answer part on this auction? seller stated that car is original 2wd. vin numbers show that it is a 2wd. what's up with the rear leaf then? stated that previous owner placed for hauling.
04-11-2007, 03:11 AM | #2 |
It's ok to stare...
Re: 70 blazer in ebay 2wd but it had leaf springs in rear
Completed auction in question. http://cgi.ebay.com/ebaymotors/1970-...QQcmdZViewItem
No 2wd Blazer/Jimmy came with leaf springs from the factory. The VIN is correct for a 2wd Blazer though. So two things are possible: 1. As the seller states the frame was switched to leafs in the rear by a previous owner. OR 2. The frame in not orginal to the truck. There should be a partial VIN number on the frame near the power steering unit (drivers side). That can be checked to see if it matches the VIN. |
04-11-2007, 03:23 AM | #3 |
It's ok to stare...
I see that the auction winner is from the same location as you, which would help to explain why your first post would be about this.
I'm not trying to call you out or anything like that, but the more information that you give us the better advice we can give you. This is a very friendly board and we are more then happy to help you out with advice. Oh and by the way |
04-11-2007, 12:51 PM | #4 | |
Thanks for the comment. Yes I am the auction winner. Car is being transported now to California. I just want to make sure that I purchased a 2wd. |
04-11-2007, 12:54 PM | #5 | |
Thanks |
04-11-2007, 01:52 PM | #6 |
Have you seen any pics of the rear leafs? Some people just don't know what they are looking at some times. If it is leaf it could have been swaped from a leaf 2wd truck as the rear frame section is the same as the 2wd unliuke the 4wd straite frame. Ether way a converted 4wd to 2wd is still worth what you paid going by his discription. Let us know more when you get it. Also welcome to the family, I am just up hwy 80 from you in Winters (out side of Vacaville).
Kevin LFD Inc. |
04-11-2007, 05:59 PM | #7 | |
04-11-2007, 11:52 AM | #8 |
SKINNY TIRES RULE!
It sounds odd that the rear was swichted to leaf springs, but there are ways of telling if it is the original 2wd frame. As Pop's mentioned, the VIN should be stamped on the frame. There are also minor differences between 2wd and 4wd frames.
Let us know if you bought the truck. We are all friendly and like to help fellow Blazer and truck owners.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
04-11-2007, 12:54 PM | #9 |
I will check the frame once I get the vehicle. What other "minor differences" are there for me to notice??
04-11-2007, 02:51 PM | #10 |
SKINNY TIRES RULE!
I was actually watching that auction too. You got a good deal on the truck. A few minor updates and it will be up to today's standards.
The seats are "utility buckets" which are stock, but not as common as the standard buckets.
04-11-2007, 03:48 PM | #11 |
My blazer has the original 2wd frame from a '70 Blazer and the body from a '69 4x4 Blazer. I researched the owners until I traced it back to the guy who did the conversion. He did it in the early '80's and he put the 4x4 body on because the 2wd got hit high in the area right behind the drivers seat. He said the 4x4's were really cheap back then and he swapped the bodys around but didn't think to keep the vin plate from the 2wd. He said the 2wd's weren't really valued as much then, so it never occurred to him to keep the vin plate.
I actually tracked this Blazer (the body anyway...) back to the first owner. Never tried to track the frame. You have a good looking Blazer, post some pics of the rear end, I'd like to see them. One other thing you might look for is if it has a bolt in transmission hump... Some 2wd's do, but a bunch of them don't. Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 04-11-2007 at 03:48 PM. |
04-11-2007, 06:07 PM | #12 | |
04-11-2007, 04:20 PM | #13 |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 04-11-2007 at 04:21 PM. |
