72' 4x4 project
My question is i have a 3-speed on column, and want 4-speed in floor. What 4-speeds will work with my 72' 4x4 truck? And where may i start looking?
Also, what inch suspintion lift do i need to run 35" or 36" tires? I hope this is in the rite forum. Thanks for your help! |
Re: 72' 4x4 project
I would use a sm465 trans with a 205 TC.
A 4" lift will let you run 35" tires.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
Re: 72' 4x4 project
Can you use a 4 speed transmission out of a 72' 2wd. can the yoke be changed out so the transfer case will bolt up? Will the transfer case bolt up to the regular transmission.
#4 | |
Re: 72' 4x4 project
You could also run the X-fer "divorced style" which would involve a short drive shaft from the tranny to the X-fer. What X-fer do you have? Some of those old I-6/3 spd combos had some kind of Dana X-fer. From what I understand, you won't want to run that behind a V8 in a full size P/U. The more info you give, the better help you'll get from the guys that know their stuff on here...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) Last edited by 1969K10; 04-12-2007 at 09:17 AM. Reason: removed "bad" word |
#5 | |
Re: 72' 4x4 project
What I am not sure about, though, is if the adapter and drive sleeve off of your current tranny/transfer will fit on an SM465. I'm guessing you already have the NP205, but it's not totally unheard of for a truck to have a Dana 20. There are plenty of pics on this website so you can ID your t-case if you can't see the tag on it. If you do have a Dana 20, you will need to source a complete SM465/NP205 combo. It can set you back probably 200-400 dollars. If you already have a NP205, you can probably get just the transmission for well under 100. If the adapter is different, you will need to find that too. Good luck!
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
