Old 04-12-2007, 09:06 PM   #1
Blue4x4
Blue4x4's Avatar
side panels and speakers in.
Just finished the side panels and speaker install. Movin on up....τΏτ
Blue4x4 is offline   Reply With Quote
Old 04-12-2007, 10:15 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: side panels and speakers in.
bump diddy bump diddy bump
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-12-2007, 10:19 PM   #3
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
You made those panels?
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-13-2007, 12:14 AM   #4
Blue4x4
Blue4x4's Avatar
Yes I did. A board member gave me a template on the sides and I traced it on to some 1/4 moisture board and cut it out. Then had it covered with the same pattern as the seats. I also have speakers in the front section on the panel.
Old 04-13-2007, 05:52 AM   #5
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Nice job. Looks good.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 04-13-2007, 08:48 AM   #6
RustyParts
RustyParts's Avatar
Bet it sounds nice with the top on and no wind blowin in your ears, looks good.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 04-13-2007, 08:03 PM   #7
jcfoote60
Active Member
jcfoote60's Avatar
did you do any brown bread or dynamat behind them on the sheet metal? How do they sound overall? I am thinking of fabbing in a particle board sub enclosure on either side where you are showing your rear 6x9's and putting in a pair of 6x9's in the front of the side panels and dial them in as fill sound. Up front I plan on making a custom fiberglass set of kicks with separates for front imaging. I will be making my own side panels as well (I had one complete stock panel when I got the Blazer). The side panel will cover the sub enclosure except the grill on the subs. Amps will be camoflauged under the rear seat. However I'm a long way from worrying about that! I am the done frame, shell of a body stage right now. Good job!!
jcfoote60 is offline   Reply With Quote
Old 04-13-2007, 08:14 PM   #8
Blue4x4
Blue4x4's Avatar
I had some extra dynamat and put it in there. Otherwise just those 4 cheap speakers. I did run the wireing for a sub but that will be for the next owner to install. I am building this one to sell.
Old 04-13-2007, 08:54 PM   #9
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Blue, did you put the carpet kit in there, or was it already installed. The reason I ask is that I like the fact that the wheel wells are covered and I would like to find out who makes the carpet kit that has them.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 04-14-2007, 06:53 AM   #10
NuBomb
NuBomb's Avatar
ABLZN - I am currently working on my interior and I bought a carpet kit from Tim Christian and the wheel well carpet was included.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 04-15-2007, 10:58 AM   #11
Blue4x4
Blue4x4's Avatar
The carpet was purchaced from summit racing. And the wheel well carpet from LMC. I used 3m spray glue to hold it in as it wasn't a perfit fit. Also wouldn't recomend the summit carpet either, It doesn't cover all the way to the sides. But after install the side panels, you can't tell.
Old 04-15-2007, 11:00 AM   #12
Southedisto
River life......
Southedisto's Avatar
Looks sweet.
Southedisto is offline   Reply With Quote
