04-14-2007, 10:23 AM | #1 |
bagged 71 0n 22"s progress pics
just wanted to show some pics of my 71,I been working on this frame for about 4 months off & on. it was a long bed when I got it, but I back half the rear to make a shorty,the rails are a little high,but rollin 22"s they need to be big.up front I did'nt want to z the frame so I channeld the front x member.I still need to cut the hoop for the drive line,plate in the x-member and cap all the pipe, I will post more when it's done
BIG ANTS 71 |
04-14-2007, 10:28 AM | #2 |
Re: bagged 71 0n 22"s progress pics
more pics.
BIG ANTS 71 |
04-14-2007, 10:36 AM | #3 |
Speechless....
04-14-2007, 12:18 PM | #4 |
cool man. Love seeing new projects on here. Got a couple questions/comments:
I would box the frame some where the new frame meets the old. I also might consider making gussets for under the link that is holding the lower bag bracket. Something like in this pic. (hard to see, but you get the idea.) Last thing, how much did you section your x-member? Did you run into any clearance problems with the inner tie rods? Last edited by jlaird; 04-14-2007 at 12:19 PM. |
04-14-2007, 03:10 PM | #5 | |
BIG ANTS 71 |
04-14-2007, 05:29 PM | #6 | |
So I don't understand how you sectioned yours more than I, yet you didn't have this problem... I guess I just have bad luck! |
04-14-2007, 06:06 PM | #7 | |
04-14-2007, 09:50 PM | #8 |
yea, I know. Thats why I was surprised when mine hit. I think slight differences in everybody's setup make all the difference. If my inner tie rod was forward a quarter inch, i would be free and clear.
04-15-2007, 09:34 AM | #9 | |
BIG ANTS 71 |
04-14-2007, 01:08 PM | #10 |
Commander Taco Bello
great work man. looks like you've done some really clean work there.
What are your plans for the driveshaft? it looks like your wishbone is gonna cause some troubles unless you do some sort of split shaft setup. |
04-14-2007, 03:17 PM | #11 | |
thanks for the comments
BIG ANTS 71 |
04-14-2007, 06:59 PM | #12 |
LOOKING GOOD
keep us posted on the new progress
http://www.cardomain.com/ride/2461088 |
04-15-2007, 11:44 AM | #13 |
thanks for the pics. Lots of variables...
04-15-2007, 01:44 PM | #14 |
whats the leanght of the wish bone and lower links ? i have a wish bone set up as well i bought off evilbay..
04-15-2007, 03:08 PM | #15 |
my lower links are 32 3/4" long and made of 1 1/2 -1/4 wall DOM upper Y is 34" made of the same stuff, I made the links and Y myself,got all my adjustable bushings and bungs from suicide doors .com
BIG ANTS 71 |
04-15-2007, 05:48 PM | #16 |
Outlandish Trends - FL
Lookin' sick! Can you post a more detailed pic of the clearancing you did to the upper control arm for the steering shaft? That's a pretty cool little mod that looks like it will eliminate having to use Borgeson joints and a fabbed bracket.
-Bret 67 short-fleet sold! |
04-15-2007, 05:55 PM | #17 | |
I still might just swap back to the stock style arm just for this reason.
04-15-2007, 09:57 PM | #18 |
67fleet,I haven't finnished that arm yet,but what I did was cut out a 2" hole just above the end nut then cut a U shaped 2" piece of pipe, weld that in to the 2" hole then grind it down level. I got this idea from a picture on IF CUSTOMS.COM they did on a 66 suburban.I'll post the pictures when I'm done.
BIG ANTS 71 |
04-15-2007, 10:55 PM | #19 |
Got a little more work done today.cut out the drive line hoop,installed the 3:89 limited slip 3rd member,pulled a trans x-member from a 87 jeep yj modified that a little(clears perfect!) just need to take it all apart and paint it
BIG ANTS 71 |
04-16-2007, 03:47 PM | #20 | |
04-16-2007, 09:16 AM | #21 |
look what I found in san francisco,
BIG ANTS 71 |
04-16-2007, 09:34 AM | #22 |
Dave's not here, man
You probably know, but in the first pic it looks like the rearend is way off center.
EDIT: I just looked again and realized you hadn't installed a track bar, so that's probably why.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 Last edited by dave2953; 04-16-2007 at 09:35 AM. |
04-18-2007, 12:57 AM | #23 |
Flat Black, & Chrome!
LOL, I've seen that very truck IRL several times, its awful...
04-16-2007, 12:27 PM | #24 |
Active Member
its because its a Ford? rear end. The yoke is not in the center. Our trucks yokes arent in the center either but are closer than that. No need for a track bar, that what hes got a wishbone for...
04-16-2007, 12:35 PM | #25 |
Big Ants 71,
lookin Good, Is the driveshaft going to work? What brand wheels are those? Any new pics with the body on? Jaredm82, Any new pics of your progress? Looks good so far! Tony from Norcal |
