Old 04-14-2007, 04:45 PM   #1
shaneschevys
Its always something!
shaneschevys's Avatar
Hooking up a 700r4
I have been reading the FAQ section on this. You hook up a 12v wire to a later model brake switch then go from the switch to the "A" pin on the trans. My question is the stock plug I have has 2 additional wires. What do they go to? Do they need to be hooked up to anything for the tranny to shift properly? The trans is out of a stock 87. No mods have been done to it.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 04-14-2007, 05:29 PM   #2
70GMCer
70GMCer's Avatar
Re: Hooking up a 700r4
One wire is 12 volts and I think the other wire is for the ground for the lock-up sol valve. You have to remove the pan to be sure, and trace the wires. Mine is an 86 trans with only the one wire and self grounding lock-up valve. While you're at it change the 3-4 shift servo and spring. Also change the 1-2 servo to a Corvette one. Cheap parts and easy to install.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-14-2007, 05:30 PM   #3
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I'm not sure what those wires do because i used the painless kit. no mods? you'd better have a light foot - the earlier 700's are known for their weaknesses. Get a higher pressure regulator for the pump - this will add years to your 700. Put a shift kit in it & I reccomend the painless wiring kit for your trans. Makes it an ez bolt in.
http://store.summitracing.com/partde...5&autoview=sku
This thing here:
alone added years to my trans my transmission guy said (before i blew it up). It lasted 11 years behind a 327/300hp motor. Dont forget to get the bracket to hook the throttle cable to the intake. Good luck & if you have questions, dont hesite to ask.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-15-2007, 03:26 AM   #4
brak
brak's Avatar
I prefer the TCI kit.
It's way cheaper than the painless kit ($75) and it allows you to add switches to control lockup. Lock it in any gear, Or disable lockup to allow towing in 4th gear (like newer trucks).
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
