04-16-2007, 09:16 PM | #1 |
front suspension
has anyone had a problem getting the front coil springs compressed to assemble the front suspention , i got a set of spring compressors from advance auto but the bolts are to big to fit between the a arms, am i doing this wrong or what
here is a couple of pics flash didn't work |
04-16-2007, 09:22 PM | #2 |
New Member
Re: front suspention
I ran into the same problem.....I ended up putting the truck up on tall jack stands supporting the frame. I then used a floor jack under the lower A arm to compress the spring. Careful not to lift the truck off the jack stands. I then was able to assemble the A arms with the spindles......may not be the prefered method but worked for me!
71 C10 SWB 350, PS, PB, 700R4 02 HD Fat Boy 03 HD Road King |
04-16-2007, 09:27 PM | #3 |
This probably wont help because it looks like you are outside but I ran a support from the top of the frame to my garage ceiling to hold the frame down then used a floor jack under the lower control arm to compress the spring.
04-16-2007, 10:14 PM | #4 | |
Crew Cut
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN D A LOT MORE JUNK |
04-16-2007, 09:26 PM | #5 |
I don't know if it was the proper way, but after trying 2 different types of spring compressors that didn't seem to work right, I removed the bump stops (to gain a couple more inches of play) and used 2 "big" pry bars to pop out the old and pop in the new. It took some time get them back in, but they finally got in there. Then used the pry bar to lift the upper control arm back up to squeeze in the bump stops.
This is just what worked for me. Good luck |
04-16-2007, 10:41 PM | #6 |
its all about the +6 inches
there is no reason to even use a compresor on a complete truck, just a floor jack under the a arm.
04-16-2007, 10:56 PM | #7 |
ive done it and it works
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
04-17-2007, 01:16 AM | #8 |
you dont need a compressor
04-17-2007, 03:43 AM | #9 |
Neighborhood Pickle Slinger
Iīll be doing that too this month and going to keep an eye on this thread.
When I get it done I will come back and give an update. From what I heard you donīt need a compressor but it helps. I got one that goes on the inside of the spring and hope it works. The bad thing is, I have to take it apart inside the spring to get it out.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
04-17-2007, 06:23 AM | #10 |
another problem i have is that it is just the frame. i even got my little brother to sit on it to try to get it to stay on the jack stands while i jacked up the a arm but everyone probly knows what happened a second later he is being pushed up also
04-17-2007, 10:03 AM | #11 |
I made a compressor from a piece of 3/4 thread rod, a 1/4x6x6 piece of flat stock, and two pieces of 1/4x2 flat stock welded together with a 3/4 nut inserted and welded in the center. I also welded a 3/4 nut on the end of the thread rod. The piece of 2x flat stock with the nut in the center is 6" long and can be inserted in the coils of the spring. Drill a 7/8" hole in the center of the 6x6 flat, put your thread rod thru with a heavy washer and nut threaded on with the washer facing the 6x6 plate. Insert the 2x flat and thread the rod into it. Insert it in the spring high enough to have enough room to compress the spring enough to release the tension. Lube the thread rod really good and this should last you for quite a few uses. I used mine to tear down just a crossmember. Worked great. Good luck.
04-17-2007, 10:09 AM | #12 |
Forgot to add the rod with the plate is inserted up thru the hole on the lower control arminto the center of the spring, and the spring is then compressed down on the lower control arm. Once the ball joint is popped you can release the tension.
04-17-2007, 10:21 AM | #13 |
Next project: 1970 K10
Unless the coils are too long, there should be no need for a compressor of any kind. Make sure the top of the spring is seated correctly, seat it in the lower control arm, and jack up the arm until the ball joints slip into place. Just the reverse for removing, put the floor jack under the lower control arm, disconnect either ball joint, and slowly lower the jack. The spring will fall out, but it won't fly out at Mach 3.
Since it is just the frame and not a complete truck, you might run a chain around the frame and under the jack. This will prevent the frame from being lifted. But it shouldn't be necessary. And a compressor is definately not necessary.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 04-17-2007 at 10:22 AM. |
04-17-2007, 01:52 PM | #14 |
Grand PooBaa Member
If you still have the 35 plus year ball joints still on the truck, you might as well break them loose, drop the lower control arm and they just fall right out.
Then you use a jack to put them back in. No need for a spring compressor, besides they are dangerous. |
04-17-2007, 09:27 PM | #15 |
well i went and got shorter bolts for the compressor i got at advance so they would fit between the a arms, i am guessing that if none of you guys had to use a compressor that i may have went overkill on the epoxy paint i put on the frame 3 coats, i had enough and figured it would be harder to chip on the dirt and gravel roads towards my house.
anyways got the spindels on and got the nuts started on the ball joints just got to get them tight enough to put the carter pins in. that last turn pulled the frame of the stands, guess i will try agian tomorrow. Last edited by creeldaddy; 04-17-2007 at 09:28 PM. |
04-17-2007, 11:10 PM | #16 |
I had the same problem with the truck on the lowboy lift.
So this is what I did, installed spring in the pocket on bottom and used a heavy duty ratchet strap to pull the arms together it worked like a charm and I didn't have to worry about the truck falling off the lift! Unconventional YES but you do what works for Ya!
1970 C10 Stepside (soon to be a 68 w/PS/PB/S&W back-half narrowed F**D 9inch w/Discs) 66 427/435 corvette motor (hopefully 871 Blower) 66 M21 4 speed (swapped in a built TH400) 31/16.5/15 Mickeys (soon to be 29.5X18.5X15 MT) 1972 C10 Stepside Pro-Street 1988 bed 3" Top Chop Custom Red Pearl paint w/overlapping Ghost Flames P/S P/W P/B P/DL P/door open Everything Shaved Frenched antenna 461CI BBC BDS Blower 1100 Dynoed HP TH400 Super Heavy Duty Full Back-Half Narrowed 12 Bolt 4:10 |
04-29-2007, 04:53 AM | #17 |
Just like I said, I would come back and give an update how I did it.
I decided not to do this myself and had a friend help me. Make sure the truck is high enough first and on good jackstands. We started by letting the lower control arm hang down to the floor and put the complete brake and hub on the lower balljoint and tightened it. We then put the spring in and raised the lower control arm up enough to get the floor jack under it. We then put 2 tie down straps around the top of the frame and the floorjack to keep the rest of the truck on the floor. After pumping the jack up and watching that the spring is sitting right we got the upper ball joint hooked and tightened. Let the jack back down. Done! No compressor needed. The first one we started wrong. We put the hub and brake on the upper control arm first and then tried to hook up the lower arm. That just donīt work! The first one took about 2 Hours and the second about 15 minutes. Learning by doing.
05-18-2007, 08:56 AM | #18 |
Re: front suspension
Floor jack...that's how I did it too!
Alex 1971 Lil' Red 350 SBC 700R4 |
05-18-2007, 09:08 AM | #19 |
Safety related - I would feel remiss if I didn't say this - and with our trucks it MIGHT NOT be an issue BUT when ever I am working with springs, knowing there is always the potential for something to "slip", I always take a piece of chain, wrap around the frame and through the spring - bolt it together and then do my thing - Like I said, it might not be needed on our trucks but I had to say it.
I was in a shop one time with an early pontiac that a guy was working on - I can't remember exactly what he had under it but we were on one side of the shop - something shifted and there was a massive "KA-BLAM!" - took a minute to figure out what did it - his support under the A arm had failed and the spring TORE a whole in the lower front of a rolling tool box - He said "hmpf, I knew I should of chained that...." ANYWHO, this is all for what it's worth and I feel better now.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
05-18-2007, 11:27 AM | #20 |
Grand PooBaa Member
05-18-2007, 11:40 PM | #21 | |
I still think the best way to go is with a compressor but they can fail too. A chain would be a good idea too just as long as it doesnīt scratch the freshly restored parts.
