Old 04-20-2007, 12:22 AM   #1
Eliasj123
Dex III in Powerglide - Help...
I know this issue is not on my '64, but my '55 has a powerglide too and you guys know your stuff..
Soo... Today, I did a lumbnuts move.. The Powerglide on my '55 leaks. I added 1/2qt of Dex III, then drove it around the block.. When I got back, I decided to read the manual... DOH!!!! TYPE "A" fluid only..
Did I hurt the tranny?? I was going to change the fluid, but do I need to flush it too??
I don't know too much about tranny fluid. I just get what the manual says.. Most of the time I read before I add fluid..
Thanks,
Elias
Eliasj123 is offline   Reply With Quote
Old 04-20-2007, 09:05 AM   #2
Jonboy
Slots go on anything!
Re: Dex III in Powerglide - Help...
It should be fine. I doubt there will be any problem. I would imagine the manual was written before there were so many types of transmission fluid.
Jonboy is offline   Reply With Quote
Old 04-20-2007, 01:00 PM   #3
Eliasj123
Should I still drain it??
I did a search on the net and found that some Dex III meet Type A requirements and others don't say either way. Do all or only some meet Type A requirements?
Thanks,
Elias
Old 04-20-2007, 02:53 PM   #4
Jonboy
I think type A requirements are actually exceeded by the dexron/mercon fluid. Type A fluid was the first, I believe. Ford used type F, which had a little different friction modifiers in it. The Dexron superceeds the type A, I believe.
