04-20-2007, 11:20 PM | #1 |
Cowboy Fan for Life!!!!!!
Suburban Tank Fuel Sending Unit Help Please.....
Hey guys, I'm installing my suburban (I think) tank this weekend and there are 4 hoses coming out of the sending unit. Can anybody tell me left to right what they are and where they go from here? Thanks guys.........Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS Last edited by Bamm; 04-20-2007 at 11:40 PM. |
04-21-2007, 04:38 AM | #2 |
Re: Suburban Tank Fuel Sending Unit Help Please.....
This is just a guess as the tank on my son's 72 Burb has the fittings made into it and the sending unit only has one tube on it, (the fuel line).
Left to right, fuel fill vent, charcoal canister, fuel line, fuel return. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
04-21-2007, 10:55 AM | #3 |
Thanks for the info Jim. Sounds like maybe the tank I have is off of a newer model? Will a '72 sending unit fit the same? Anybody know? Any help would be great. Thanks, ....Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
04-21-2007, 01:54 PM | #4 |
Thats not a newer sending unit, at least it looks the same as mine (I just had the tank out) 2 & 4 are vent lines.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
04-21-2007, 05:49 PM | #5 |
Where do they vent to? Sorry, I don't have a clue on this one. I have only had in cab tanks. If (left to right) hose #1 is fuel going out, and #2 and #4 are vent lines, what is #3? Return? If so, return from where? Thanks guys for helping me out.........Jerry
04-21-2007, 08:26 PM | #6 |
I'm not sure if 1 or 3 is line to fuel pump (popping the cover off will tell you for sure) the other is like Jim said 'fuel fill vent' (there should be another smaller connection on you fuel fill pipe). By the way good luck finding the proper size fuel fill connector hose, and then its about a $1 an inch.
04-22-2007, 12:25 AM | #7 |
I took the unit out and here's what I know: #2 has some kind of little small filter doo-dad that only drops down into the tank about 1 1/2 inches. Filter? Vent? Line #3 is definitely the fuel pickup line. #4 looks to be a skinny vent line? #1 is the largest diameter line but I don't know what it's for. I'll try to snap a pic of it tomorrow to see if that helps jog anybodies memory. Thanks Larry and everybody else for helping me with this. Later, .........Jerry
04-22-2007, 12:33 AM | #8 |
Jim and I both have said #1 is a vent line that goes to the fuel filler inlet (where you pump the gas in) if you look up inside the fender where it comes thru you will see a nipple where the hose goes.
04-22-2007, 08:17 AM | #9 |
#2 can be used as a vent if your truck is not set up with the charcoal canister. #4 would be used on trucks that have AC so that part of thefuel being pumped to the engine is returned to the tank, (the fuel pump would have two outlet connections on it it with the small line going back to the tank).
Depending on how your truck is set up, you may not need #4 but you will need 1,2, and 3. Jim
