I have Mohave tires
79 Blazer Cheyenne, 2wd 305 3.42 stock 85 Caprice, TBI converted, new 350 crate motor, Monte Carlo SS Wheels, Bilstein shocks, |
Weekend Warrior
Re: Towing with P235/75/15
My 1st guess would be the wheelbase is the route of the problems. the shorter the wheelbase the more "Squirly" it will be in all conditions.
as for the tires - I guess just use a quality 235/75R15. My buddy and I have towed regularly on all differant brands of tires in that size. Always towing a Full Open car trailer with anywhere from 2-5k on it less the trailer weight. Never a problem - towing 65-70mph.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
Son of a gun
It probably had more to do with how you had the wieght of the vehicle distributed on the trailer. Too much or too little wieght where it needs to be will cause that squirrely feeling
Bill BEATERS ARE NEATER |
![]() Join Date: Aug 2005
The normal "P" (passenger) rated tires are not usually rated to tow such heavy loads which might have caused some of your towing akwardness. You could always step up to an "LT" 6ply tire or a XL (extra load) "P" rated tire. With the XL tire you don't give up so much of your ride quality as you would with the heavier duty LT tire. In a lot of cases the XL tire can even handle more weight than the LT.
'73 C-30 3+3 Dually 454/TH400 '74 Fleetside 350/TH350 (SOLD) '69 Nova 350/TH350 (project FOR SALE) '63 Nova 305/TH350 3.73 posi (the wife's project) |
glamoros piece o' lowlife
P235/75-15 tires do NOT belong in trucks, period, not even in half-tons. One of the truck magazines actually did a test with a late-model Ford F150 with P-rated and then LT-rated tires, don't remember what exactly the test was but the LT-rated tires just pounded over the regular passenger car ones. How important it is to have the right tires should be suggested to you by the fact my car (yes, the car, not the truck) rolls on LT235/75-15 tires, and even the spare is a LT215-75/15. My car clocks the scales at about 4250lbs with no passengers or cargo, and I don't drive fast or tow heavy stuff like you... Hell, even my 245/60-15 summer tires are the 4-ply high-load type. So yeah, switch to actual truck tires, ride change will be minor, however handling will improve greatly. That, and you know the "better safe than sorry" principle and how much trouble it saves if followed.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
K5Camper
![]() Join Date: Mar 2004
Tires are one thing, but towing with a blazer just isn't going to be as stable as a LWB truck. Add to that fact if you put the car on the trailer and gave it too much tounge wieght and it makes it worse. Too much tounge wieght has the tendancy to unload the front wheels. Meaning the rear squats and the front end comes up. You don't have enough wieght on the front tires to keep them planted. It's kind of like driving a 1/2 ton truck with two tons of rocks in the bed. It will carry the load but just won't track straight.
I'm not saying towing can't be done with a Blazer, but that due to the short WB you have to pay closer attention to wieght distribution. Heck I've towed my 69 nova on a open trailer with a 1/2 ton Z71 and the only way we could keep the front end of the truck from going sky high was to turn the car around backwards. The wieght was distributed better on the trailer and less on the tounge. The truck leveled out and pulled pretty well. Had we left with the car facing forwards it would have probably been dangerous to drive at highway speeds. That was with a longer WB truck than your Blazer too.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
I see I should be a lot better off with real truck tires. I am thinking about putting the michelins up front and buying Pirelli
Scorpion ATR's Load range D for the back untill the michelins wear out. I would hate to waste the good michelins LTX's. Or maybe I could sell them. They have always been on the back axle, so they have exellent even tire wear. It would cost $300 total just for two tires. Pirelli Scorpion ATR appears to be a great tire. What do you think?
I would agree with Zoomad and Bus. Loading a trailer, even with a 3/4 or 1 ton truck can make a huge difference. While there are problems with loading the tongue too heavy, I think it is more dangerous to load the tongue too light. If you load the trailer with all of the weight on the back, it can cause the trailer to whiplash like mad at highway speeds. But you do need to get rid of those tires, or at lest stop towing until you do.
