Old 04-23-2007, 05:46 PM   #1
jnd
New Member
Escutcheon problems
Is there a "trick" to installing the aftermarket escutcheon/washers that fit between trim panel assembly and the inside door handles & window cranks on the 67-71 pick-ups? We have purchased 12 in the past few weeks from various vendors and each one cracked/split around the seam found on the circumference of the part. In fact a couple split before we even had them installed in the panel. Thanks.
jnd is offline   Reply With Quote
Old 04-24-2007, 05:16 AM   #2
Mudder
Mudder's Avatar
Re: Escutcheon problems
Have had trouble getting a few of them in from time to time but never had any crack.
Mudder is offline   Reply With Quote
Old 04-24-2007, 07:31 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I had the same problem. Apparantly the aftermarket ones are made poorly. I wound up buying mine from GM. They are still available through the dealer, but only in black color. The GM ones never gave me any trouble.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-24-2007, 11:35 AM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
They are a little difficult to install...almost like they are just a little too big. I have not broken any but wanted to...LOL! I get mine from Truck Shop in Orange, CA. I might try the GM units however.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 04-24-2007, 03:24 PM   #5
jnd
New Member
Thank you for the responses folks. I think I will go the OEM route and see if SEM can provide a paint/dye to match the saddle color. Tx Firefighter, would you happen to know the GM part number, or where I could do some research for it? Thank you!
Old 04-24-2007, 04:20 PM   #6
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
12338082 for 69-70, not sure if it'll work on earlier models or not.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 04-24-2007, 07:07 PM   #7
jnd
New Member
Thanks BACKYARD88. Ordered them today, will pick up on Friday. Thanks again to all who replied.
Old 04-24-2007, 08:41 PM   #8
stllookn
stllookn's Avatar
If you don't mind me asking...how much were the GM units?
Old 04-24-2007, 10:23 PM   #9
BACKYARD88
BACKYARD88's Avatar
I can't remember the exact price. I ordered a couple today and I think they listed for 3 or 4 dollars a piece.
Edit: 3.07 a piece plus tax.
-Mike Owen-
Old 04-25-2007, 09:02 AM   #10
BACKYARD88
BACKYARD88's Avatar
Here's mine:
-Mike Owen-
Old 04-26-2007, 05:53 PM   #11
jnd
New Member
I do not mind. They cost me $2.48 each including tax. Had to buy a package of five for that price.
Old 04-26-2007, 10:58 PM   #12
jorgensensc
jorgensensc's Avatar
Will these work on a '68?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
