04-24-2007, 01:48 AM | #1 |
Fix It Till It's Broke
Shimming a starter
So I was going to replace the old worn out starter today and when I took the old one out I realized it had a shim with it. I had yet to put the new one in because I didn't know or pay attention to how the old shim was in there...sorry if this is a stupid question but thanks for taking your time to answer it if you do
04-24-2007, 05:49 AM | #2 |
Re: Shimming a starter
The starter noses vary sometimes and the starter may need shimmed because of that or irregularities in the block. I would try the new one without the shim and see if it engages alright. If it grinds or seems to act weird, try the shim between the starter and where it mates up.
04-24-2007, 07:20 AM | #3 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
If the inspection cover is off you can check the clearance between the fllywheel and the starter shaft.
Here's a good article on it. http://www.carcraft.com/howto/2988/index3.html
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
04-24-2007, 10:42 PM | #4 | |
This is a great article. Easy read ..... lots of good info. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
04-24-2007, 07:27 AM | #5 |
Oh ya,make sure the rear support bracket is installed.It GREATLY prolongs the life of the starter.
Sorry no pic's of it on the truck.
04-24-2007, 08:14 AM | #6 |
blood type; Retumbo
there should be 1/8" between the starter shaft and the teeth of the ring gear. I use a brazing rod with the flux scraped off as a gauge.
04-24-2007, 09:25 AM | #7 |
Designated A-hole!
Most new starters come with a set of shims and a rod to check the clearance. I've always heard of the brace, but I've never actually seen one.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-24-2007, 10:44 AM | #8 |
Saving 1 truck at a time!
Krue...me too...but I just found one on an old block and installed it on my new sb 400. Problem is that it just makes the terminals harder to access...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
04-24-2007, 11:31 AM | #9 |
That's usually why they're never reinstalled.
Thing is once they ARE installed the need to access the wires becomes rare. I'm going on 6 years with my starter.It's only a reman. from PepBoys.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 04-24-2007 at 11:33 AM. |
04-24-2007, 01:47 PM | #10 |
Self-proclaimed LED man
on my second one i used two shims, the first rebuilt starter i bought i didnt use any shims and it broke the nose of the housing from being too close to the gears. Had to replace the starter and flexplate This is very important to check!!!! Flexplates arent easy to replace!!! lol lesson learned.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor Last edited by 724x4a/cchevy; 04-24-2007 at 01:48 PM. |
04-24-2007, 02:18 PM | #11 |
Black 72 Chevy
BobbyK
I installed a bracket like that on my starter for a 350 engine and that cured all my grinding problems. A.P.
72 Chevy, SWB, 350engine, TH400 |
04-24-2007, 09:08 PM | #12 |
I know the starter bracket is getting away from the shimming a starter question but, any idea where to get one of these brackets for a BB?
Ironhead Mike '68 Panel 402BB '84 Shortbox 4X4 '85 Blazer '97 Silverado Ext. Cab |
04-25-2007, 02:50 AM | #13 | |
That pic I posted was from Classic Industries catalog. Here is the whole page.The prices have prob. gone up since my catalog is from 2000-2001. Click the link for a full sized pic. http://images23.fotki.com/v803/fileR...scan001001.jpg
04-25-2007, 01:41 AM | #14 |
I need to do this too. My starter would only engage about 10 percent of the time, always 'spinning off' and not grabbing. Dont know if these means my starter is going bad or I need shims.
So I got some shims and started with 2 shims, it grabbed good once or twice then kept spinning. 4 shims were no better. Might take off my starter to have it checked.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
04-25-2007, 02:40 AM | #15 | |
C10 now is a GMC
Please keep me imformed on what you find out on your truck. My '62 is doing the exact same thing. I need to get this truck operational asap. David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
05-03-2007, 11:46 AM | #16 | |
Thanks guys!
04-25-2007, 09:53 AM | #17 |
Pat: you need to shim the outer bolt only. Cut the shim to fit under this bolt only. Start with 2. This will set the teeth deeper in the flywheel.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
04-25-2007, 09:40 PM | #18 |
Starter noise during cranking can be caused by too much clearance between pinion and flywheel. If shimmed, try removing shim or only shim outer bolt only. A whining noise after engine fires / as key is released can be from pinion and dlywheel being too close. Try shimming both sides until noise stops. I check the clearance between the pinion and flywheel or flexplate by using a heavy wire with a hook on the end of it to reach in and pull out the starter clutch until it engages the flywheel. You need to rotate the flywheel so a pinion gear tooth is centered between two flywheel teeth. Use a .020" wire gage. Hope this is helpful.
05-05-2007, 10:12 PM | #19 |
Scratch that, the next day it wouldnt work. I played with shims for about an hour with no luck. I went to get my starter tested and it worked, but the guy there said he really couldnt make sure b/c he couldnt put it under a load to see if it was getting weak. He mentioned something about GM changing the bolts from a 3/8 to a 10mm or something, and said there was a possibility of that causing enough of a misalignment. Plus the bolts were supposed to fit snugly in the starter, mine were very loose. So I bought a new starter and 2 new bolts and it works perfectly, no shims either.
05-05-2007, 11:14 PM | #20 |
It's the air up here
Mostly GM starters work with no shims. The cheep after market starters some times need them, but ac/delco not often. GM squares and trues all mounting surfaces.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric Last edited by eedgell; 05-05-2007 at 11:14 PM. |
