04-28-2007, 01:08 AM | #1 |
It's the air up here
frame swap/ 79 to 71 question
Anyone out there ever swap a 67-72 body to 73 up frame in 4x4? Are the frames different?
edgell |
04-28-2007, 12:30 PM | #2 |
Re: frame swap/ 79 to 71 question
They are doable but different.
04-28-2007, 12:43 PM | #3 |
The frames on the newer 73-87s have different designs and when you do this,you have to use a body lift.The frames are longer on the 73-87s too
04-28-2007, 02:47 PM | #4 |
My buddy did it years ago it wasn't worth it!!!!!!!!!!! nothing fit right.
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!! |
04-28-2007, 09:03 PM | #5 |
Junior Member
How much body lift and what are we needing to clear?
Old Chevys never die they are just reborn! |
04-28-2007, 09:07 PM | #6 |
I think 3" is what you need.Its needed to clear the frame as its bent different and is quite different in the back.Keep in mind that rear cab mounts will need fabbed up too,the 73-87 had the rear mounts inside the frame.The person to talk to is Randy(mudder).He sent me an email with pics and info on this swap
04-28-2007, 09:16 PM | #7 |
i,ve got one thats done that way. i,ve never paid close attention to it colsely though. its a 4x4 3/4 or 1 ton. theres about 4" behind the cab thats open. look out of porportion to me .
bob |
04-30-2007, 12:03 AM | #8 | |
Bloo
i just looked at buying one this weekend-- i would say dont do it, it looks kinda unstable to me from the one i looked at. but, here is what i noticed:
they used a flat plate bolted from left rear cab mount to right rear mount on the cab, and drilled two holes in it above the 78 mounts (inside the frame rail) to bolt the cab down there was about a 3" body lift on it they used a 2wd cab with a hole cut in the floor, NP203 t-case, full time 4wd there was 4-5" between the cab and bed they used a 78 bumper... i have no idea if a 67-72 one would fit the rear 67-72 bumper was plastered against the bed-- i think the bumper could be spaced or the bed slid forward though
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
04-30-2007, 12:25 AM | #9 |
The swap can be done and if done right can have advantages over the older frames. Having probably thousands look my truck over I bet there have been fewer than 25 ask if it was a newer frame. Some may have known and just walked away but it sorta goes to show ya that if done right it can look alright. You do need to shorten the frame and you can get by with less body lift if you watch what you do.
04-30-2007, 05:12 PM | #10 | |
I might just have to sneak up and mention it at Indy this year... j/k |
04-30-2007, 05:34 PM | #11 |
On "Old Blue" shes sitting on a 85 3/4ton frame used a 3" body lift on the bed and front end custom body mount in the front of the cab with 1 hockey puck and 1 puck in the back of the cab
its not a street truck but its been holding up for what ive been doing with it |
04-30-2007, 01:16 AM | #12 |
Bloo
ive seen mudder's truck in person, and even ridden in it.. i will say his is defintly not noticable. if i hadnt known it was done i would have never guessed it
