Old 04-29-2007, 07:10 PM   #1
Cody chance
rear drop
i have rear leaf spring and i want to drop it. Is the axle flip and c-notch the only way to go and is that a 6" drop?
Cody chance is offline   Reply With Quote
Old 04-29-2007, 07:35 PM   #2
Cody chance
Re: rear drop
early classics has a 4" drop leaf spring with a 1 1/2" drop shakles. thats probably the best way to as far a quality and ride quality right?
Old 04-29-2007, 07:50 PM   #3
cdowns
cdowns's Avatar
Re: rear drop
try finding somebody local that makes springs/ you might just be able to get springs built with reversed eyes at a cheaper price
Old 04-29-2007, 11:57 PM   #4
corn
Re: rear drop
Not the only way to go but yes, it is 6"...
corn is offline   Reply With Quote
Old 04-30-2007, 10:52 AM   #5
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: rear drop
The c-notch is only going to provide clearance for the axle after it is dropped... It has nothing to do with the drop itself. As far as the flip goes, it should give you about 5.5". The nice thing about flipping the axle is that you are not changing the function of the rear suspension at all. You are merely taking the axle from the bottom of the spring and putting it on top. You will, however, need to make sure you get your pinion angles right and you will need a set of shorter shocks.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 04-30-2007, 05:45 PM   #6
BigTruckDriver
BigTruckDriver's Avatar
Re: rear drop
You could add shock extenders and keep your shocks. Flipping the rear end and c-notches really go hand in hand. If you dont c-notch you will only have about 2 clearance inbetween the rear end tubes and the bottom of the frame. Flipping could be the way to go because you will keep you stock springs so ride quality wont be affected to much.
BigTruckDriver is offline   Reply With Quote
Old 05-01-2007, 03:46 PM   #7
72MARIO
72MARIO's Avatar
Re: rear drop
I just did a Axel flip on my 67.Mine turned out to be closer toa 6.5 " drop. EDIT there is only 1 1/4 " of travel. Adding the notch wil give you a extra 1 3/4" before the axel hits the wood floor . If you have a steel floor you have a extra 1/2" before the axel hits the floor. They make the notch way too big.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
