Motor running hot? 210 Degrees!
I just put some new summit racing gauges in my truck and it seems that my water temp is running around 210 degrees. The motor is a 250ci. I replaced the thermostat and checked inside my radiator and it looks real clean inside. It does have 2 small damaged spots on it about 1inch in size. Ive seen ones in worse shape that still work fine so i dont think its that. The antifreeze might be a little on the strong side, i dont think it has much water mixed with it. I did not put it in so im not sure about that. Would that make it run hot? It also doesnt have a fan shroud, but i havent seen a stock fan shroud on a 250ci before. Did they come with one? Would an after market fan help? Dont really want to buy a new radiator if i dont have to. Thanks for any help guys.
Re: Motor running hot? 210 Degrees!
i'd check with an accurate thermometer or thermocouple before spending money changing anything /just because the gauge is new is no guarantee that its accurate
#3 | |
Sierra Grande Club
![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
As said above it wouldn't hurt to put a themometer in the radiator for a second opinion. What temp thermostat are you using? How far away is the fan from the radiator?
My truck also reads 212 Degrees at operating temperature. I thought this is normal. I maybe wrong...---Andy
1972 Chevy Truck 350ci/th350 Auto. Daily Driver ![]() |
Im using a 195 degree thermostat. I believe that is what came in it stock, and thats what the old one was. Everything is stock so the fan is only about 2 inches from the radiator.
Some might argue, but I personally would use a 180 thermostat instead. That fan distance sound about right.
Watch out for your cornhole !
![]() Join Date: Jun 2003
It's not the thermostat. If it's running higher than the t-stat rating, a lower temp stat isn't going to help anything.
General rules of thumb: If it overheats setting still or moving slowly, it's an airflow problem. If it overheats while driving, it's a coolant flow problem.
#9 | |
I survived Dead Man's Curve.
I will note that the auto parts store's computer (don't know how reliable that is ![]()
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. ![]() |
#10 | |
Realize the thermostat wont open until the engine gets to 195, but should close after the temp drops allowing the coolant in the radiator to cool. If the thermostat is not closing the temp could keep climbing, does it level off at 210 or do you turn it off when it reaches 210? And have you driven it on the freeway at speed to see where the temp is with air circulating through the radiator. Does the vehicle have A/C? Have you checked for a blockage of the air flow maybe a plastic bag or something on the front of the radiator. Just a technician throwing out ideas.
my 327 runs at 210. is that too hot?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
i wouldnt say that 210 is bad
where are you guys getting the idea that the stat closes when its at temp? and if it stays open that the temp will climb??? are you just letting it idle in the driveway while youre doing this or have you driven it and gotten this???
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
I took it for a ride and it leveled off around 200-210 when i was going about 55mph. when i got home and turned the engine off the tempature rised to about 225 degrees. I guess this would be because the engine is not circulating the water anymore. Does this sound right?
#15 |
if the engine is off then the temp gauge shouldnt climb up more
is it a electric one or mechanicle?
#16 |
its a mechanical one. I opened the hood when i got home and could hear the water, it sounded like it was boiling in the upper hose or something. When i looked at the gauge it was rising from 210 to about 225. Not sure what to think, i had a 250ci before and i remeber it always seemed to run hot, but not doing anything wierd like this. Thanks again for all the replies!
#17 |
sounds like somethings up with that thing if its sittin there and the temp is rising when its not running, where do you have the gauge sensor?
#18 | |
The slight temp rise at shut down sounds normal. A 195 t-stat will initially open at around 200+ Once it settles down the t-stat will be partially open to maintain the temp (approx 195 degrees) by slightly restricting the coolant flow. Engine heats up from a load, the stat opens more to adjust. When the engine load decrease, the stat will restrict some to slow down the fow of coolant and keep the temp up. When you shut down the engine it will heat soak the coolant around the engine and the stat will open fully. got to get back to work... You still may have a cooling system problem or a blown head gasket. |
#19 |
OK, I read all this and had some thoughts.
210 is not too crazy, but if you hear it "boiling" inside the motor, your flow may be restricted somewhere. Antifreeze is just that... it keeps the fluid from freezing in the winter, but it doesn't conduct heat as well as water. Thus the recommended 50 percent mix. You might also check your timing... I've had them run hot when it was close but not on. Does it knock a little before shutting off? |
#20 |
![]() Join Date: Aug 2006
I agree completely with the timing issue. I run Pontiacs and the timing has to be just about dead on or they run hot. Also check your fluid level in the rad. Water boils at 212*f or 100*c at sea level. Glycol with the pressure will raise the boiling point. If the level is low you may be getting steam pockets in your cooling system and that is where the rumble is coming from. Whatever you do, don't touch the rad cap until that thing settles down. I've seen coolant come up out of a rad like a geyser, hit the underside of the hood and cover the poor guy trying to add water to his rad. That leaves a pretty good mark that you don't forget too soon even if you are only a spectator. Good luck.
#21 |
In addition to the above opinions...
My understanding is that the t-stat is there for initial warmup of the engine. Once open, it isn't going to close until the engine is shut off and it cools. Regarding the temp (of the coolant) increasing when the engine is turned off, this is normal. The coolant cools the engine, and airflow through the radiator cools the coolant. Right after the engine is turned off, the coolant is still removing heat from the engine, but there's no airflow to remove the heat from the coolant. I'm not sure if 210 is high, but it depends on the temp where oil breaks down. You don't want to get the oil too hot. You may want to drain, reverse flush, and refill with a correct mix of water/antifreeze. Also, think about the radiator cap. Its meant to allow the system to build pressure, which increases the boiling point of the coolant. Doesn't seem like an issue here, since water boils at wat 265F? Sorry that's one of many facts I didn't memorize. Last edited by 72lb4x4; 04-30-2007 at 02:10 AM. |
#22 |
^exactly^
#23 | |
not quite, if the coolant gets too cool the t-stat will close. specialy when you live in a cool place. most of the time it will stay open but there is times when it closes.
#24 | |
Lol, thats not hot at all, my old Camaro would run 215-220 all the time.
Hell...the electric fans wouldnt even kick on till 245-250 degrees.
#25 |
FWIW, ive got a 180 stat in mine with the stock 350 and stock 1 row rad and the stock gauge, once it warms up sits on the second line all the time
