Old 05-05-2007, 09:22 AM   #1
92470
What routes through the valve cover clips?
Does anyone know what wiring was originally routed through the clips that were on factory valve covers? I have a 71' Cheyenne 350 and noticed these 2 clips on the top of them that are metal and part of the valve cover, but can't figure out what their purpose is?
I know it's not the plugs wires and on the driver side thought it might be the temperature sending unit wiring. I can't seem to find out anything in my scematics, but I know some of you have better ones.
Any help is appreciated.
Thanks!
92470 is offline   Reply With Quote
Old 05-05-2007, 09:28 AM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: What routes through the valve cover clips?
IIRC mine had some senser wires that ran along the valve cover.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 05-05-2007, 09:48 AM   #3
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Intakes that had temperature sensor's installed the wires were routed using these clips and with the older Vettes when aluminum valve covers were used clips were installed to run temperature sensor wires a long the valve covers. I just looked @ a 71' factory intake and there is no provision for a temperature sensor. I looked at a set of 71' valve covers & the clips are visable. Did different years use different intakes but used all the same valve covers .... beats me.
Sorry I can't be of more help ....
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 05-05-2007, 07:20 PM   #4
Aarons72s
Its for the tempertaure sending unit wire, the sender should be between the #1 and #3 plugs. It also routed the wire for the fast idle solenoide that was on some trucks too.
Aarons72s is offline   Reply With Quote
Old 05-05-2007, 07:38 PM   #5
eedgell
It's the air up here
eedgell's Avatar
alternator? A/C? GM is real good at making one piece fit everything
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-05-2007, 11:24 PM   #6
wibilly
wibilly's Avatar
i didn't think the clips came along until later unless your talking about clips that bolt on with the valve cover bolts
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 05-06-2007, 03:55 AM   #7
jkeady
jkeady's Avatar
On my '70 with 350, the temp sensor wire runs down the driver's side valve cover, and I believe the vacuum line for the distributor runs down the passenger side.
EDIT: Through the clips that are spot-welded to the valve covers, that is.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 05-06-2007, 06:50 AM   #8
GREASEMONKEY72
GREASEMONKEY72's Avatar
the 2 little clips on the valve cover is for the temp senser wire to run through to the senser thats on the side inbetween the #1 and #3 plugs
just like Aarons72s said
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
