Old 05-06-2007, 12:03 AM   #1
Ricks1971
Ricks1971's Avatar
engine towers question?
Hey guys I have a question about big block and small block engine towers? I took a set of these towers out of a 1971 3/4 ton big block truck and a set out of a 1972 3/4 ton with a small block and the towers are exactly the same. Should they of been different? Thanks Rick
Ricks1971 is offline   Reply With Quote
Old 05-06-2007, 11:04 AM   #2
Ricks1971
Ricks1971's Avatar
Re: engine towers question?
Bump?
Old 05-06-2007, 11:22 AM   #3
Americanrider
Posted pics of what you have would be helpful. The black set is 69-71, the others (slighty rusted) are 72 only BB mounts. Small block tower have small holes in the center. About 5/8th's I think.
Americanrider is offline   Reply With Quote
Old 05-06-2007, 11:57 PM   #4
Ricks1971
Ricks1971's Avatar
both sets look the set on the left. I thought that there was a difference between big block and small block towers. Oh well!
Old 05-07-2007, 04:20 AM   #5
gus
rick towers are different on angle, I just finished installing a 90'454 on my 71 2wd had a 350 on it and I tried to use same towers but oil pan on big block was sitting on top of the cross member, some one had told me to use any BB towers from 73's87's I tried it and they were to high off by 3", so my only option was early classic or truck shop in Orange CA both same arm and a leg but it did work ! original GM towers with motor mounts $360 very expensive for conversions from 350 to 396-502s
gus is offline   Reply With Quote
Old 05-12-2007, 12:09 AM   #6
Ricks1971
Ricks1971's Avatar
Gus, the set of towers I took off the 71 with a big block in it are exactly like the set I took off a 72 with a small block? I just wonder if its the motor mounts that might be different from a big block to a small block. I'll clean them up a take a pic and post them tomorrow
Old 05-12-2007, 03:48 PM   #7
Ricks1971
Ricks1971's Avatar
as you can see these towers look the same? one set off a 72 with a small block and the other set off a 71 with a big block?
Old 05-12-2007, 04:50 PM   #8
71 super
71 super's Avatar
Congrats it looks like you have two sets of 68-71 big block mounts. Stands are not worth as much as 72 only but with the rubber inserts can still bring good money. Looks like someone switched original set in the 72 out at some point.
71 super is offline   Reply With Quote
Old 06-17-2007, 11:50 PM   #9
So,what do we have here?Are these mounts exactly as stated or were some switched at some point.If totally original,than 68-71 SBC towers will work for a BBC,right?
Old 06-18-2007, 10:21 AM   #10
stude283
ok,so what actually is the difference in the mounting position of the motor?
Does the bb sit higher and why is this necessary? Is the motor offset in the frame and why?I know bb and sb normally bolt in place of each other so why not in our trucks?Thanks to all for your valuable help and information!
stude283 is offline   Reply With Quote
Old 06-18-2007, 12:07 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
First off those in the picture look to be 68-71 Big Block towers. If you for found a set in a 72 then someone changed them. The reason for the different mounts is location of the engine, strength of the motor mounts, and less stress on the chassis. Big Blocks tend to break the weaker, less flexible small block mounts quite regularly and the design does not absorb the extra torque of the Big Block. Causing extra stress on the chassis. The Big Block towers have a larger hole in the center for the 3 piece motor mounts. The 3 piece motor mounts put rubber on top and bottom of the big block towers, with a metal tube that slips through the entire works. When the engine is bolted down with this, it alows for the extra torque of the big block. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 06-19-2007, 09:04 AM   #12
Thanks,I appreciate that explaination.That was my question,if we knew if those towers are original to the truck.
