Old 05-06-2007, 08:00 PM   #1
solidaxel
solidaxel's Avatar
Column Ignition keylock
I have a tilt column in my 55 GMC and I need to replace the key lock. How many different locks are there? It was a automatic without the dimmer switch and the indicator is NOT mounted on the column.
I went to a car show and entered the truck and left the keys in the ignition and some a$$ took my keys. I guess that is what I get for trusting people!!
Thanks for the help
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-06-2007, 10:20 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Column Ignition keylock
If you take the old one out then take it to a NAPA auto parts store they should be able to match it up with the description you posted.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 05-07-2007, 10:58 AM   #3
Zoomad75
K5Camper
Zoomad75's Avatar
IIRC, the lock cylinder on the column is pretty much the same piece for tilt/non tilt or with the dimmer or without. Problem is you usually need the key in the lock to be able to remove the lock cylinder from the column.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 05-07-2007, 11:18 AM   #4
solidaxel
solidaxel's Avatar
No problem there I have a second key but I don't want the a$$ running around with a set of keys to my truck!
Looks like I will need to change the door locks also, but I have another set of doors so I will remove the handles and trade the locks out, after I have keys made!!!! So what you are saying is all the lock cylinders are the same for GM's!
LS 3 4L70E
