05-09-2007, 10:52 PM | #1 |
saving one more
please id this rear axle
Just bought a 69 short wide and it has this rear axle. I have no idea what it is. It is a six lug rear axle. Anyone know what this rear axle is?
Thanks for the help.
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
05-09-2007, 10:56 PM | #2 |
Re: please id this rear axle
Eaton....I think thats it..Maybe,I don't know the Eaton axles that good
05-09-2007, 11:35 PM | #3 |
It's the air up here
Eaton
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric |
05-09-2007, 11:44 PM | #4 |
you know how much we all like pics, how about some of the entire truck
Justin 1970 c/10 short wide bed WTT 1970 chevy front end for 67/68 chevy front end WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
05-10-2007, 12:44 AM | #5 |
I quess there is a first time for everything but I have never seen a six lug Eaton. All of them I have seen were 8 lug and had bolt in axles at the outside hub. Get a picture of the front of the housing. Also the track bar shouldn't look like that.
69 Chevelle SS 375/396 TKO 600 71 Suburban 3/4 4x4 402 5-speed (project) 68 chevy C10 shortbed 327 5-speed (project) 72 Blazer 4x4 400 4-speed (wifes project) Numerous 67-72 parts trucks |
05-10-2007, 01:09 AM | #6 |
There should be numbers to the right of the pumpkin that would help
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
05-10-2007, 06:37 AM | #7 |
It could be an older corporate axle. Similar in design to the HO52/HO72 but used in half ton applications. I believe they called it an HO33.
Tim |
05-10-2007, 06:54 AM | #8 |
I think Blazer1970 is right. I hate passing on second hand info, but have been told that a semi-float 6-lug with small tubes is the HO33 that was used in half-tons.
Josh '70 Custom Camper / 20 |
05-10-2007, 09:45 AM | #9 |
saving one more
pics of front of axle and one of the truck as found and purchased. I have a long way to go.
I am not seeing any numbers to the right of the carrier, should these be on the right axle tube? Again thanks for the help.
05-10-2007, 10:23 AM | #10 |
The Older Generation
The code is stamped on the passenger side tube of the rear end housing. The first picture shows the area of the housing where the code is stamped and the second picture is of the code number itself. When You have the code just use the first two or three letters ('67-'69 have two letters & '70-'72 have three) and look it up here in the axle codes section. http://www.americanclassic.com/paint.htm It doesn't tell you who made it though. The letters TDE on this one tells me it is a 307:1 - 1/2 ton assembly LockDoc
05-10-2007, 11:25 AM | #11 | |
saving one more
I am at a loss here....
05-10-2007, 10:32 AM | #12 |
its all about the +6 inches
never seen that in a 67-72 1/2 ton.
05-10-2007, 10:57 AM | #13 |
Ive never seen one like that in a 67-72 either. But my 1955 1/2 ton truck had one like that. So it must be a older axle like Blazer1970 said.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
05-10-2007, 11:29 AM | #14 |
saving one more
story of my life, I am thinking of changing my nick to "I ain't seen nothing like that before"
Thanks again.
05-10-2007, 10:06 PM | #15 |
saving one more
anyone else have an idea what this rear axle is?
05-11-2007, 10:21 AM | #16 |
Id say it is what evryone says, the ho33. But I bet it came out of a 60-62? 1/2 ton. They had the same suspension as ours so it is possible to use the axle out of one. I believe 62 was the last year, please correct me if I am wrong. I think also a 67-72 with a ho52 that has coils might be able to supply you with a new panhard bar since yours is messed up. Hope this helps.
05-11-2007, 10:33 AM | #17 |
Recovering Truck Driver
it strongly resembles the axle that was under a 61 1/2 ton apache short step I used to have.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
