whats the max lift i could put on a 4X4 gmc jimmy with out having to drop the transfer case?? i know id have to extend brakelines, linkage exc exc.
thanks!! |
Re: Max Lift?
no one knows??? common, i dont wanna have a wicked drive shaft angle
Future TOTM Winner
Re: Max Lift?
4 inch is a safe bet. By the time you get to 6 inch you usually have to lengthen the driveshafts or drop the trans case or something to help your driveshafts. If you are only on the street and you are just going for looks, then I don't think the driveshaft angel itself will be a problem with a 6in, but the length will. If your are hard core into off roading it will be a different story.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 05-11-2007 at 10:05 AM. |
River life......
Re: Max Lift?
I have a four inch lift with the transfer case dropped 3/8" and I have no problems at all.
Future TOTM Winner
Re: Max Lift?
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Re: Max Lift?
