Old 05-10-2007, 10:45 PM   #1
bodyman9174
will this work??
Hey all I bought a 1988 GMC yesterday really cheap. Pretty much just a work truck till I get done with my 71. My question is will the wireing,brain box,TBI set up, steering column,seat belts, seat, work in the 71. U all think it would be a good switch over? Or leave the the 71 carbed and with all the orig stuff
and keep the 88 for the winter?
JAY
Cars i have done
bodyman9174 is offline   Reply With Quote
Old 05-10-2007, 11:11 PM   #2
72chevy327
Re: will this work??
I am doing almost the same swap only with the tbi just to get the extra gas mileage and adjust ability. haven't started fitting stuff yet but i will be starting soon. carbed is cool too but the gas bill isint so cool.
72chevy327 is offline   Reply With Quote
Old 05-10-2007, 11:17 PM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Steering column is not easily converted, but it is possible as I did it to mine
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 05-10-2007, 11:25 PM   #4
smalltowncowboy
if you switch over to TBI you will need the fuel lines, pump, and more than likely the tank. (not exact PSI) the TBI runs off 16PSI and the carb only runs off of 4-7 PSI. also if you switch the brain the best way to do it is with a new aftermarket wiring harness to cut out things you wont be running that will give your engine bad readings.
if you can get all you need then it is a good swap.
your like a prize mouth bass, i dont know weather to eat you or mount you.
1978 chevy stepside, 2002 dodge crew cab
AMSOIL DEALER
smalltowncowboy is offline   Reply With Quote
Old 05-11-2007, 12:08 AM   #5
bodyman9174
hey Spray-Bomb u have any pics of it? How hard was it to switch over. Done really seem to hard to do.
And about the tank I just order the one that goes under the bed. I could use a inline fuel pump right?
Cars i have done
Old 05-11-2007, 01:44 AM   #6
smalltowncowboy
you can use an inline one as long as the PSI is right but id back it up with an inline fuel pressure guage.
AMSOIL DEALER
Old 05-10-2007, 11:24 PM   #7
st1x10
st1x10's Avatar
Column would be the hardest due to the fact that it is a thicker column.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 05-11-2007, 05:03 AM   #8
brak
brak's Avatar
Install a blazer tank, and the sending unit from a later fuel injected model (88-91) and that will give you in tank fuel pump that you need.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
