Old 09-11-2002, 12:04 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Question Flashers stopped working
I was replacing my turn signal cam the other day and now my flashers don't work in the dash. They work outside the truck. My turn signals do still work in the dash. My flasher switch is new. Is it possible when I had the cam apart I didn't install the brass contacts back the way they were. I switched these contacts and 4 little springs over to the new cam. My cam and switch are the 67 style. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-11-2002, 01:41 PM   #2
Fast68Chevy
Fast68Chevy's Avatar
if any lights anywhere flahs the id be looking at bulb problem or bad contact at bulb base problem or ground problem at back of dash, sounds like may be time for scrwewdriver and WD40 and some housecleaning on the dash.
good luck
Fast68Chevy is offline   Reply With Quote
