05-12-2007, 11:57 PM | #1 |
Flat Black, & Chrome!
Just finished, 9:00PM
I just came in from putting the 5" flip kit on the back of my truck, been working in the dark for about an hour now, but it was worth it! I set the rear back on the ground, and I must say its looking awsome, even without a bed on it! Pics in the morning, and the front gets some 2.5" spindles tomorrow too!
05-13-2007, 12:16 AM | #2 |
Cruzzzn' Vet
Re: Just finished, 9:00PM
Sounds good.
Be waiting to see those pics Last edited by Malo83; 05-13-2007 at 12:17 AM. |
05-13-2007, 02:27 AM | #3 |
nice, get some dame pics which c notches did you use weld in or bolt in?
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq |
05-13-2007, 11:05 AM | #4 |
I have the bolt on's, havent got them on yet though.
05-13-2007, 06:01 AM | #5 |
It Is What It Is,,,,
Good deal Im getting ready to toos ona flip too. What kit did ya use, and did you use air tools or not? C-Notch did ya do it?
And yes me too. waiting for the pics!
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
05-13-2007, 11:06 AM | #6 |
I got it at Gmcpauls, and I think if I didnt use air tools I never would have gotten any of the bolts off! C Notch I'm going to try and do today.
05-13-2007, 11:59 AM | #7 |
Happy to be here
Ok, so it's day time now. Where are the pics?
05-13-2007, 12:39 PM | #8 |
I'm trying to grind off the rivets holding the old bump stops on, I'll get some pics now
05-13-2007, 02:02 PM | #9 |
U Bolts are still loose, I cant find a socket deep enough to get to the bolt, and I dont want to cut the u bolts.
Eventual goal: |
05-13-2007, 04:37 PM | #10 |
Happy to be here
Looks good. Your not going to find a socket that deep. Like Scoti said, re-use the stock u-bolts, or whack them suckers of...
05-13-2007, 02:29 PM | #11 |
no socket deep enough = open end wrench, tighten down very evenly and very tight.
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
05-13-2007, 02:31 PM | #12 |
Re-use the stock bolts w/the 'new' nuts or cut the new bolts.
05-13-2007, 02:39 PM | #13 |
Cruzzzn' Vet
Did you mount the saddles with the holes FWD
05-13-2007, 02:41 PM | #14 |
Saddle is the part that goes under the axel correct? If so, then yes the hole is to the front.
05-13-2007, 04:48 PM | #15 |
nice man, good luck with it
05-13-2007, 08:01 PM | #16 |
The One And Only !!!
Cut those U bolts, They don't look good sticking waaay down there.
Lookin good other than that.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
05-13-2007, 10:22 PM | #17 |
glamoros piece o' lowlife
Agreed, it's just a matter of time till you run something over and get it caught on them U-bolts and either bend or twist something.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
05-13-2007, 10:25 PM | #18 |
I'll try and cut em or put the old ones back in tomorrow, I'm doing like 3 or 4 diffrent things on my truck at a time right now, lol its a good thing I'm not driving it yet.
05-13-2007, 11:30 PM | #19 |
67 Chevy Stepside
did you weld that flip kit in. i did my on my first truck and just wondering what most people do
1967 Chevy stepside 1976 BIG DOOLEY 454 turbo 400 4:11 |
05-13-2007, 08:57 PM | #20 |
Garage Queen Material
i just used an open wrench to do mine... it kinda sucked
also, remove your bump stops while your bed is off after i did the flip kit on my truck and sat it back down, the axles where riding on the bump stops, so i had NO suspension travel in the rear. and when i say remove them, i mean everything not just the rubber. you'll need to drill our grind off the stock rivets |
05-13-2007, 10:12 PM | #21 |
67 Chevy Stepside
good job
05-14-2007, 12:35 AM | #22 |
I am debating getting a weld in or bolt in.
05-14-2007, 05:45 AM | #23 |
Looking good,, If you havent already,, but I agree,, run up the old bolts and cut them muthas off,, It will give a clean look.
05-14-2007, 02:11 PM | #24 |
I used the same flip kit and c-notches from GMC Pauls. I cut off the u-bolts but left about an inch sticking down. Here is how it looks with them cut. I agree that they were way too long before!
1984 Chevy Stepside, 4spd granny, 4 1/2 front/6 inch rear drop. |
05-14-2007, 08:27 PM | #25 |
That looks pretty nice! I think I may just have to keep the new u bolts and use the old ones though, because I like a lower drop, I'll just get blocks and use the new u bolts at that time.
