05-13-2007, 06:28 PM | #1 |
Help Please on air ride!!!!!!!!!!!!!!!!!!!
I am ready to start on my air ride could some give a lise of good setup for front and rear i want to have it as low as possible without cutting up through floor of bed.........i would really appericate the help and could i see some pick of some good setups.....THanks for your help guys.....
05-15-2007, 12:52 PM | #2 |
Junior Member
Re: Help Please on air ride!!!!!!!!!!!!!!!!!!!
What year ?
05-15-2007, 06:10 PM | #3 |
1969 gmc shortbed
05-20-2007, 06:55 PM | #4 |
just go to ***************** and they will set you up nice. if you want high qiulity high end stuff, air ride had front and rear strong arms for your truck. but for the front i used SD's front brackets and slam specialties bags.
05-21-2007, 10:00 PM | #5 |
soon to be bagged64sub
I used all Suicide doors stuff.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
05-21-2007, 10:02 PM | #6 |
its leaf springs truck i don't know wat to do in back to match up with 2.5 drop spindles in front and bags...to level it out.....
05-22-2007, 12:46 AM | #7 |
leaf springs???? i thought 67-72 shortbeds came with coils? you can order one of ***************** 's 4 link kits, or if you want to go cheap, you can remove some leafs and order some sleeve bags and brackets and a good size notch for the rear. you will still need valves and all that. how much you want to spend?
05-22-2007, 10:22 AM | #8 |
A lot of GMC's are leaf. Your best be is to either use a stock trailing arm type setup, or go 4 link.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
