Old 05-15-2007, 02:06 AM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Ram Air setup, pics please?
I am finishing up my truck this month, will post pics when complete.
I am adding a ram air setup.
I want to pick up the air right at the grill.
Thinking of this grill mod to allow space for the pickup hoses. I remember in high school we used to collect the air by dumping the inside headlights [4 light systems] and picking up the air through the second headlight housing
How are you picking up your cold air for your ram air setups? What are you using for the ends?
Thanks,
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 05-15-2007, 06:25 AM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Ram Air setup, pics please?
you could run hoses to pick up the air underneath the bumper, or cut holes in the rad support and run the hoses from the grill, through the support and to the aircleaner
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-15-2007, 07:07 AM   #3
Huck
Huck's Avatar
Keep in mind that you don't necessarly need a round hole to pick up the forced through the rad suppot. Had a porsche that picked up air from oval scoups mounted on the top of the rad support --between it and the hood--and routed the cool air back on both sides of the V8 to inlet at the rear of the block at the firewall. (928S4)--it also had air inlets that forced air directly to the front disc's for cooling. Both GM and Ford had dual intake air cleaners for easy hookup. using a GMC firewall would give you the dual hole but ----headlight placement might be an issue. Definitely a nice upgrade that many will watch to see you solution. Huck
Huck is offline   Reply With Quote
Old 05-15-2007, 10:40 AM   #4
WinDancer
WinDancer's Avatar
Planning on running the hoses thru the core support to the grill. Hoping someone has done this and will post a couple of picks
Dave
Old 05-15-2007, 11:33 AM   #5
WinDancer
WinDancer's Avatar
Here is the setup I am using for the ram air- still looking for ideas about the actual pick-up collectors. Something a little larger, maybe?
Thanks,
Dave
Old 05-15-2007, 12:21 PM   #6
NONHOG
NONHOG's Avatar
what about from the firewall like this type ?
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 05-15-2007, 02:32 PM   #7
71STPSDE
71STPSDE's Avatar
[ATTACH]Name:  Picture 1 155.jpg
Size:  71.1 KB[/ATTACH]Here is a picture of mine. The PO installed it. I don't know who makes it.
71 Chevy Stepside
377/350
71STPSDE is offline   Reply With Quote
Old 05-15-2007, 02:36 PM   #8
DangerBoy
I've been workin on this project for a while too, just haven't had time to complete any of it past the design stage. http://www.ramairbox.com/ makes the one above.
2002 S10 ZR2 for the dirt.
1968 C10 shorty for the street.
She said the truck would be the end of us. I still have the truck!
DangerBoy is offline   Reply With Quote
Old 05-15-2007, 03:02 PM   #9
Hooker
aka TEX-TOY
Hooker's Avatar
i am thinking about attaching a hose to the firewall so that i can draw in the air from the windshield.... Does anyone have any thoughts on this?
1969 Chevy C10 SWB w/ disk brakes and soon to be lowered with spindles and springs!!!! Getting a paint job like a Army Chinook Helicopter!!!! HOOKERS RULE!!
BRAND NEW WIFE BOUGHT IT FOR ME AS A WEDDING GIFT!!! SHE IS THE BOMB!!!!!!
Hooker is offline   Reply With Quote
Old 05-15-2007, 03:39 PM   #10
Ole Blue 68
Ole Blue 68's Avatar
What kind of gains do you all figure a setup like this will give you?
Ole Blue 68 is offline   Reply With Quote
Old 05-15-2007, 03:47 PM   #11
WinDancer
WinDancer's Avatar
There doesn't seem to be much actual measured data- everyone just says 'substantial boost' in HP. A pilot friend says that you have to be going more than 100 mph for any gain from the ram effect. Most everyone agrees that the additional cold air can't hurt
Dave
Old 05-15-2007, 04:07 PM   #12
Ole Blue 68
That's what I was thinking. I can see a bigger gain on newer cars from opening up a closed air filter box but not so much on one of our trucks. Let me know how it works out though, I'd consider it for mine.
Old 05-15-2007, 04:37 PM   #13
WinDancer
WinDancer's Avatar
here is a pic from :
www.ramairbox.com
This is how we did it in high school
Dave
Old 05-15-2007, 03:58 PM   #14
WinDancer
WinDancer's Avatar
71STPSDE, what does it look like going through the core support, and what is on the other side of the core support that is actually collecting the air into the tubes? Your setup looks almost identical to what I want to do- gather up the cold air [or at least colder than in the engine compartment], run it through the core support and then dump it into the air box. I want to use rectangular pickups outside the core support that will stand up and down in the new space outside the inner and outer grill so they show from the front of the truck. Couple more pics, please?
Thanks,
Dave
Old 05-15-2007, 07:26 PM   #15
71STPSDE
71STPSDE's Avatar
Thanks,
I'm out of state right know. From what I can remember, on the other side of the core support, is the back of the grill. Sorry I can't help right know. Hopefully end of this month.
71 Chevy Stepside
377/350
Old 05-15-2007, 07:49 PM   #16
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
For my k5, i was thinking of using a ram air setup. I was just gonna cut up an old hood and put a mustang-style scoop.
I am interested in who makes that dual snorkle setup, looks like it sits on a 360 degree filter. If someone got me a brand name it would be appreciated. Thanks
R.spence
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 05-15-2007, 08:21 PM   #17
jorgensensc
jorgensensc's Avatar
Something to keep in mind is all the ridges on the hose actually causes turbulance in the air and in some instances hurt performance, so I've been told. Would be nice for a nice smooth hose though.
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-15-2007, 08:58 PM   #18
WinDancer
WinDancer's Avatar
I got my setup from Summit, Jegs sells a kit, too. Google Ram Air Box and settle down to read for a while
The engineers say the turbulence is eliminated by the heavy filter, which also is supposed to trap water when it rains. We will see.........
Dave
Old 05-20-2007, 02:21 AM   #19
WinDancer
WinDancer's Avatar
Got the core support cut, ran the hoses from the grill, through the support and then up to the dual pickups on the air box.
Gonna just leave it like that until I get it road-worthy again, next weekend.
I think I'm gonna search around a little more for a larger, funnel-shaped pickup at the grill. I am not happy with the size of the collector ends and want a little more flow. My mechanic says it is a total waste to spend all this money on a bib block and then quiet down the sounds of the engine suckin' air. He wants the air scoops in the glove box so you can hear 'em
I had a cover built for my gas tank filler by a sheet metal/furnace guy. I may ask him to build me something I can live with if nothing else works.
Pics tomorrow if I can find the charger for the camera.
Dave
Old 05-20-2007, 03:58 AM   #20
GREASEMONKEY72
better find that charger so we can see the pictures
-steven
Alte Seele S.S.
Old 05-20-2007, 10:10 AM   #21
kbs71
71 rustless in texas
kbs71's Avatar
WinDancer go back and look at this http://www.ramairbox.com/snorkels.html. The round metal inlets (4/5/6FLC) could probably be picked up at a hardware store or some place that does duct work for less than what ramairbox wants for them.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
