Old 05-15-2007, 10:48 PM   #1
Evans
Evans's Avatar
3/4 length Chevelle headers ???
Which ones fit the best ?? I don't want to trim the frame rails to make them fit.... Are they all 3 bolt flange ??
Evans is offline   Reply With Quote
Old 05-16-2007, 01:14 PM   #2
Bowtie001
Project underway - finally.
Bowtie001's Avatar
Re: 3/4 length Chevelle headers ???
I'd like to know this too so bump for you.
1972 GMC Pre-resto... awaiting allocated funding.
Bowtie001 is offline   Reply With Quote
Old 05-16-2007, 03:44 PM   #3
nvrforgotten52
nvrforgotten52's Avatar
me too
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 05-16-2007, 03:57 PM   #4
1lowdiesel
1lowdiesel's Avatar
i've got chevelle long tubes on mine. they fit great but it's a pain to get the plugs out and you have to run heat sheild or wrap on the wires too. i have pics if ya need em'
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 05-16-2007, 04:00 PM   #5
1lowdiesel
1lowdiesel's Avatar
xtremediesel.com
Old 05-16-2007, 04:03 PM   #6
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
http://67-72chevytrucks.com/vboard/s...ad.php?t=87422
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
Old 05-16-2007, 08:15 PM   #7
Bowtie001
Bowtie001's Avatar
A lot of those old links no longer point to the correct thing - I was able to find the Sanderson links, but I was curious to see some others. Are there any of header manufacturer that makes these that anyone has on a truck? What year Chevelle and what part numbers?
As a side issue - anyone know if a column shift will fit?
Thanks!!!
-Brian
Old 05-16-2007, 09:09 PM   #8
byrd
Union Electrician
byrd's Avatar
Shane in the link posted above said his worked, I believe they are sandersons?? I bought a set of camaro/chevelle headers and they would not fit, the DS hit the motor mount by about an 1". So I eneded up using 88-95 truck headers and they fit nicely with a litle trimming, and no issues with plugs or wires as they will be underneath
Here is a link to my build thread to the page showing my headers, there is enough room to get to all the plugs and the headers go stay up instead of going straight down allowing more room for the wires and starter clearance
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-17-2007, 12:36 PM   #9
1lowdiesel
1lowdiesel's Avatar
the ones i used were dynomax pn# 85001
xtremediesel.com
Old 05-17-2007, 01:18 PM   #10
sneezys72
I bought a set of hedmans that didn't work. I think they were part #68600. The driver side hit the motor mount. I used a set of the 88-95 truck shorties. With a little trimming on the driver side frame, they fit great. Hope this helps.
sneezys72 is offline   Reply With Quote
Old 05-17-2007, 03:53 PM   #11
Bamm
Bamm's Avatar
Hey diesel, I keep looking up Hedman pn# 85001 and keep getting a mustang header? Have you got a link to your headers? Thanks, ......Bamm
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 05-17-2007, 04:21 PM   #12
Bamm
Bamm's Avatar
Gotcha...... Dynomax #85001...... Thanks Diesel............
3/4 Drop 350/700R4
Tilt wheel
My Zip is 23002
I ship UPS, USPS
Old 05-17-2007, 04:53 PM   #13
Shane
Shane's Avatar
The one's I used are Dynomax ...
Shane is offline   Reply With Quote
Old 05-17-2007, 05:43 PM   #14
Evans
Evans's Avatar
Shane what was the part# on yours ??? The 85001's are longtubes....
Old 05-17-2007, 07:56 PM   #15
Shane
Shane's Avatar
I bought them several years ago and have no clue on the part number. I searched and it looks like my headers are now obsolete ... can't find them on the Jeg's or the Summit website.
Old 05-17-2007, 10:16 PM   #16
Stroker
I think I may have the PN for the headers shane used. I happened to save a very old post on this subject.
http://67-72chevytrucks.com/vboard/s...ad.php?t=14688
It looks like Jegs may still carry them.
http://www.jegs.com/webapp/wcs/store...86118&x=10&y=8
http://www.jegs.com/webapp/wcs/store...10002_16250_-1 Looks like they went up to $299
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 05-17-2007, 11:05 PM   #17
BigTruckDriver
BigTruckDriver's Avatar
Do these headers hang below the frame? I am looking for some that dont go below the frame.
I have always called Hooker Headers and they give you headers that fit a small block perfectly, for about 130 dollars. They are full length and go below the frame.
BigTruckDriver is offline   Reply With Quote
Old 05-17-2007, 11:22 PM   #18
c10crazy
Like a Rock!
c10crazy's Avatar
Keep in mind all shorty headers are only 1.5" tubes!.
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 05-18-2007, 01:15 AM   #19
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Most of them are, but not all... The 3/4 length Chevelle / Malibu headers have 1-5/8" primaries. I tried 2 different styles and unfortunately, I found that they did not fit to my liking (interference with the motor mounts). I searched some more and found a set of Edelbrock shorties that are listed for a 96-98 Pickup, Tahoe, Avalanche...
http://store.summitracing.com/partde...5&autoview=sku
They fit with only a slight notch required in the upper frame rail on the driver's side. They were a bit of a compromise because they have an o2 sensor tube coming off the back of the driver's side header. I had it cut off and tigged closed so now you can't even tell it was there. Here are some pictures.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 05-18-2007, 06:35 AM   #20
byrd
Union Electrician
byrd's Avatar
Here is a pic of mine 88-95 truck headers(fro White performance) and what I really like about them is the front primary goes up instead of down like the chevelle headers and that will let me run the plug wires under them so you can't really see them, outa sight outa mind just my .02...Randy
Zip:40272
Old 05-18-2007, 07:51 AM   #21
Bowtie001
Bowtie001's Avatar
Has anyone used anything from the Hedman Elite line? They make shortys both for our trucks and for Chevelles that look great and are reasonably priced for ceramics. Anyone?
Summit part nos
Trucks: HED-69648
Chevelles: HED-68608
-Brian
