Old 05-18-2007, 11:04 PM   #1
Paul72
Paul72's Avatar
Question - engine mounts for 700R4 trans?
I'm going to be installing my 700R4 into the GMC next week and would like to move the engine forward rather than shorten the DS.
Looking for ideas/pics/suggestions of what others have done to relocate the engine mounts successfully.
Thanks in advance,
Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family
Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958
Paul72 is offline   Reply With Quote
Old 05-19-2007, 06:13 AM   #2
70GMCer
70GMCer's Avatar
Re: Question - engine mounts for 700R4 trans?
won't work!! The engine won't go forward enough. You'll have to cut the driveshaft 3", assuming that your 700 has the short tail housing.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-19-2007, 08:07 AM   #3
cdowns
cdowns's Avatar
maybe you could lengthen the frame fenders and hood by 3inches to move the engine foreward , that would save you the trouble of shortening the driveshaft
Old 05-19-2007, 09:13 AM   #4
Paul72
Paul72's Avatar
I've got a welder, torch, and steel plate - it's going to work somehow. I am just looking for others' ideas before I come up with my own.
I know there have been others that have done this........
Old 05-19-2007, 09:31 AM   #5
smokekiki
Mike
smokekiki's Avatar
If you are talking about that 4X4,the 700 is only 1 3/4" longer.More than enough room to move the engine forward.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 05-19-2007, 08:47 PM   #6
Paul72
Paul72's Avatar
Any stories of success?
I'm heading up Tuesday night and back on Memorial Day.
Old 05-21-2007, 06:50 AM   #7
smoky02
Location: Sunny, Florida, some might call it South Alabama
I've just installed a 700 in my truck and I'm getting a drive shaft cut...
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 05-21-2007, 07:31 AM   #8
mrein3
mrein3's Avatar
Paul72 -
I went to the gas station Saturday. $111.40 later I'm reconsidering my choice of th350 over the 700r4 when I switched from manual to auto. PLEASE keep this thread up to date with your progress.
I still have the spreadsheet I used to help me decide th350 over 700r4. At that time gas was $1.60/gallon. I figured I'd have to pay $3.20/gallon to make it worth the extra dollars for the 700 rebuild, etc.
Saturday it was $3.38/gallon.
The general concensus on this subject is to move your engine forward and leave the drive shafts alone. There is enough room to do this because the factory V8 engine position is tight against the firewall.
Again. Please update this thread with your progress.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 05-21-2007, 03:27 PM   #9
nvrforgotten52
nvrforgotten52's Avatar
two wheel drive will be cutting it close... 4wd should work fine... i moved my mounts forward an inch or so but i wasnt using a stock driveshaft i pieced one together that was a bit shorter that the stock one i had.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 05-21-2007, 04:04 PM   #10
kelsfine69
18 Till I Die
kelsfine69's Avatar
IMO it seems like a lot less work to shorten the driveshaft??
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-21-2007, 08:03 PM   #11
Smitty
Smitty's Avatar
I'm with kelsfine69, I made that change into a 71 short 2WD. And everything went well and I have many troublefree miles on it since.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 05-21-2007, 08:18 PM   #12
snj8198
snj8198's Avatar
I have to agree. granted it would be nice to gain a little room between the firewall and dizzy, but chopping the rear and lenthening the front drive shafts is alot less work. I've got $300 total into my custom shafts with new joints, CV, longer slip shafts and balanced, built from scratch. -steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
