Acrophobic clutch pedal.
The clutch pedal in my 78 c10 doesn't want to come back up after being depressed all the way to the floor. Everything works fine and it runs & drives great but if I push it all the way to the floor sometimes I have to put my toe under and pull it up a little bit to get it to pop back up. Dead pressure plate?
THE VILLIAGE IDIOT
Re: Acrophobic clutch pedal.
dont they have a spring under the dash...been so long since i messed with mine i forget...or is it a psring on the frame..
honestly honey,,i have no idea how that truck got here. ![]() |
The problem you describe sounds like your linkage is binding. Have an assistant do the pedal (engine off, brake set, trans in neutral), while you watch the linkage.
There are 2 springs, one under the dash, and one under the truck, near the bellhousing. The spring under the dash is the heavy spring that returns the pedal.
1970 long fleet, 355 4 speed, primer, walnut goodies |
