Old 05-19-2007, 04:07 PM   #1
Evans
Evans's Avatar
Front spring removal ???
Whats the easiest way to get the front springs out ??? undo shock and pop out upper or lower ball joint with jack under lower a-arm to lower slowly ???
Evans is offline   Reply With Quote
Old 05-19-2007, 04:14 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Front spring removal ???
That's how I did mine. I loosened the lower ball joint nut, supporting the truck on a jack stand. I knocked the LBJ loose, took the ball joint nut off and SLOWLY lowered down the control arm.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 05-19-2007, 04:51 PM   #3
lowdowndirtyshame67
Don't be sceered! As long as none your body parts and valuables are not underneath it, just remove the shock and lower ball joint castle nut and give the steering knuckle a good wack with a MFAT (Maximum Force Adjusting Tool) and let 'er fly! There is really not much pressure left on the lower control arm from the spring, and between the ground and the steering knuckle and the rest of the suspension, the spring really can't go far...FYI...
lowdowndirtyshame67 is offline   Reply With Quote
Old 05-19-2007, 06:10 PM   #4
Evans
Evans's Avatar
Thanks guys !!! Was wondering which was easier top or bottom BJ , seems the bottom is the prefered.
