05-20-2007, 01:52 PM | #1 |
Bolting 205 adapter plate to crossmember--what size bolts to use?
Ok,so I'm getting close (as in between now and next week) to bolting the motor,tranny,and t-case in the 71 shortbed.Now,the truck didn't have the drivetrain,or the bolts so I have no clue what size of bolts to use.
So...I think the bolts that go in the side of the 205 for the "torque bracket" are 5/8'' coarse thread, about 1 1/4'' long...correct? What size bolts do I use that go in the bottom that connect the crossmember to the t-case? Thanks, Dustin |
05-20-2007, 06:39 PM | #2 |
Aluminum slot wheels rule...
Re: Bolting 205 to crossmember--what size bolts to use?
They are fairly long, like 3 1/2" thread maybe?, and they are 5/8" coarse thread. I could go pull one out and measure it for you, but I'm not that kind of guy.
05-22-2007, 05:59 PM | #3 |
It's the air up here
All the 205's I have been around are: 1 inch long x 5/8 on the torque bracket, and 3 inch long x 1/2 on the main mounts. All course threads.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c Never drink down stream of the herd! Eric |
05-23-2007, 07:07 PM | #4 |
Thanks guys.I just bought some bolts like mentioned above and they worked...Now I have a transfer case to bolt in friday...
05-24-2007, 07:13 PM | #5 |
Wait, aren't the crossmember bolts 5/8" thread as well? or do they have a 5/8" bolt head? Can't remember, been too long.
05-24-2007, 07:48 PM | #6 |
I bought the size eedgell posted and they seemed to work.
05-25-2007, 12:18 AM | #7 |
3/4 and 15/16 head size.
05-25-2007, 08:14 AM | #8 |
I don't think my T-case bolted to a crossmember, only torque arm. I know the transmission bolted to it's crossmember, My T-case crossmember has a skid plate rivetted to it. It's a 221 Rockwell though so it might be different.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-25-2007, 11:25 AM | #9 |
Mine don't either.....It bolts to the adapter plate which bolts to the crossmember.I'd have to look at my rockwell t case I have,I dont remember how it mounts.
05-25-2007, 01:59 PM | #10 |
Well,I got the transfer case in....the bolts were the right kind but the ones that bolt in the adapter werent long enough.Luckily I found one to work for now but I'm going to have to get some longer bolts eventually
05-25-2007, 09:24 PM | #11 |
Re: Bolting 205 adapter plate to crossmember--what size bolts to use?
Well...I managed to find some grade 8 bolts the right thread,and right size to use so now the transfer case is completely bolted down....next is the tranny and motor
05-26-2007, 04:45 PM | #12 |
3 inch long 1/2 bolts were not long enough? What did you have to use?
05-26-2007, 07:21 PM | #13 |
I used ones close to 4" long.They stick out of the adapter,but they work.Should the t-case have room to move forward and back some while its bolted down,I think it should have some room to move,but how much?
05-26-2007, 07:41 PM | #14 |
Wow! you must have some thick mounts or something. The T-case sould be able to move for and aft but not much more than the cross member allows. The cross member should bolt to the adapter with little deflection.
05-27-2007, 06:47 PM | #15 |
Yes,the mounts are thick,but the bolts do stick out of the adapter a lot.
I was out in the shop today while it rained and the transfer case all bolted down moves forward and back about 1/2-3/4"...to much? Last edited by 1969k10stepside; 05-27-2007 at 06:48 PM. |
05-28-2007, 12:27 PM | #16 |
Are you bolted to your torque bracket?
05-28-2007, 02:42 PM | #17 |
Yep
05-28-2007, 03:04 PM | #18 |
You should be good. You need some give when you install the engine and "suck" everything up tight. 1/2 inch is the world sometimes!
