Old 05-20-2007, 03:44 PM   #1
hellrazrblade
Purple People Eater
hellrazrblade's Avatar
Soft Top Question
Do soft tops "go bad" if they are just sitting in the box for a while? I'm looking at buying an unused soft top, but its been sitting in the box for 10 years. Are there any problems that I might encounter?
1971 K5 Blazer 396ci/TH400/NP205/Dana 44/GM 12 Bolt/38" TSLs
2004 Chevy 1500 4X2 X-Cab 327ci
hellrazrblade is offline   Reply With Quote
Old 05-20-2007, 03:52 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Soft Top Question
I guess it would depend on the environment in which it was stored. The vinyl my get brittle, but I would think that it being in the box would keep it from most factors that could cause it to get brittle, like the sun or electrical ozone.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-20-2007, 04:18 PM   #3
hellrazrblade
Purple People Eater
It's garage-kept in the midwest, so probably exposed to a pretty large temperature range.
Old 05-20-2007, 07:55 PM   #4
Jimmy72custom
Jimmy72custom's Avatar
A mouse moved into mine and chewed a hole in the rear flap.
Jimmy72custom is offline   Reply With Quote
Old 05-20-2007, 08:20 PM   #5
hellrazrblade
Purple People Eater
I hadn't even considered the mouse factor. Thanks for the info guys.
Old 05-20-2007, 08:31 PM   #6
bouncytruck
SKINNY TIRES RULE!
If it is cheap enough, you could could probably get the vinyl part remade. The hardware is the hardest part to make and you can use the old top as a template.
As of right now, there is only one choice for new soft tops - Bestop.
bouncytruck 1972 K5
Old 05-21-2007, 11:42 AM   #7
Yukon Jack
Yukon Jack's Avatar
I agree with bouncytruck - if the material is in bad shape it can still be used for a pattern - the hardware is the part that is really important. Any idea what brand it is?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-22-2007, 06:41 PM   #8
hellrazrblade
Purple People Eater
This one isn't cheap enough to make it worth buying and getting a new piece of fabric cut. Its a tiger top (if it were a fast track type, I'd be much more inclined to pick it up).
