05-21-2007, 08:24 PM | #1 |
Junior Member
so dont laught at me for a dumb question... :)
what all is involved with changing the rear end from opendiff to posi?
05-21-2007, 08:25 PM | #2 |
Re: so dont laught at me for a dumb question... :)
05-21-2007, 08:28 PM | #3 |
More or less a full rear end re build. The carrier needs to be replaced with a posi unit and if you are doing that you will want to change the bearings and seals. Do you have the right ring and pinion that you want ? If not do that at the same time. Or just find a used rear end that has a good posi. Personaly I would have a shop set it all up for you because the labor is cheap compaired to the parts. So if you do it wrong it will get very $$$
Kevin LFD Inc. |
05-21-2007, 08:49 PM | #4 |
Junior Member
well based on your threads, if *you* say axel swap, ill take your word for it.
