Old 05-24-2007, 11:00 AM   #1
FrankHoy
FrankHoy's Avatar
? on Cab body part replacement order
I am looking for some guidance on best order to do metal replacement & repair, to ensure proper fit, strength and support.
I need to replace much of the lower metal in my cab. Such as both rocker panels, floor sections, cab supports, rear cab corners.
I looked through the FAQs but did not see any that covered this. I remember reading a thread that did discuss this, though it has been a while.
Any guidance or references greatly appreciated.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach
(upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL)
71 Custom Deluxe 350/350 Tilt/PS/PB
00 Blazer
FrankHoy is offline   Reply With Quote
Old 05-25-2007, 08:56 AM   #2
Re: ? on Cab body part replacement order
All I know is do your rockers with the doors mounted.Do as much as you can with it mocked-up.It`s best to set the cab on a frame to tack the floor/support parts in place for alignment.I`d do the floor/supports/corners/rockers similtainiously with tack welds until all is well aligned.Mock-up with clamps all you can before even tacking.
Old 05-25-2007, 01:48 PM   #3
BigSky71
LAIDOUT
BigSky71's Avatar
There's probably lots of theories, but I did mine in this order; inner kick panels, floor, A pillar, beer, B pillar, inner rocker, beer, cab corner, the outer rocker, and beer.
The inner kick and floor were more like the same time because you have to have both of them cut before welding in either...
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 05-25-2007, 06:08 PM   #4
jaros44sr
jaros44sr's Avatar
Thanks for the advice, I knew I messed up somewhere. Didn't quite get the beer thing down in the right order. I'll do it better the next time around... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
