04-28-2002, 05:28 PM | #1 |
ok, gotta plug oil pressure hole in rear of block
ok, since the brass screw in fitting for oil pressure has broken off and will not come out with EZ out and heat or by melting wax into the threads, i have no choice but to plug the hole, i figure soem kind of tapping screw of some kind and some sealer should block it, max prssure woiuld be 60 psi, it seems, so would have to be a preety good plug
anyoen with a good trick or ideas or info, im gonna dig through napa store;'s hardware drawars in the mornign and see what i can find for a flat head tapping screw of some kind Il worry about findin another place to tap oil pressure gauge line into some other day thanks ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
04-28-2002, 05:39 PM | #2 |
Big Block Power
Try using a LH threaded bolt, as soon as it bottoms out it should back the brass fitting out, it has worked for me in the past.
------------------ 69 CST 10 496/700R4 10.40 @ 135mph, and its street legal!!!! 89 F/S Blazer 388, vortec blower,(eats SST's and s@!ts Lightnings) 67 Chevelle 350H/327, L79 screamer!! 97 Grand Am GT (wifes car)its not all that fast but it handles awesome!! Its not how much it costs, it how well you hide it from your wife!!!! |
04-28-2002, 06:55 PM | #3 |
its all about the +6 inches
Sears sels drill bits like that too, but you'll pay quite a bit for them though. (no pun intended)
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
04-28-2002, 07:16 PM | #4 |
finding exact size bolt that isneeded to fit inside the fitting would be needle in haystack i think, will try and see whats at napa, thats all we got for stores here with hardware automitive related
lol @ pun, heh thanks ------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
04-28-2002, 08:07 PM | #5 |
dude wouldnt an easy out work? it would be the same as the left handed bolt trick only they are tapered from big on the end with and small on the other. easy outs are awesome.
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
04-28-2002, 08:55 PM | #6 |
try a piece of square bar stock it will work better than an easy out because they seem to spread the brass tighter. taper the end of the bar stock and tap it in. a old screwdriver and a pair of channel locks may also do the same thing. snowman
