05-29-2007, 07:50 PM | #1 |
Active Member
bent tailgate
Has anyone taken a tailgate apart to straighten it? The outside on mine looks straight. It's the inside thats bent about 1/2 to 3/4 inch. Dont know if this is even possible.
69 C10 LWB Project 47 Cushman Scooter Project It is better to have loved and lost than to live with a psycho all your life. |
05-29-2007, 08:04 PM | #2 |
Re: bent tailgate
i believe you can take them apart and weld it back up
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-29-2007, 08:04 PM | #3 |
Re: bent tailgate
Yep. I had bought a new aftermarket tailgate and it sucked. The only reason I bought one was because the inside of my gate was pretty beat up and beyond repair. Wasn't too hard to accomplish and came out very good......click on my build thread below.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
05-29-2007, 10:18 PM | #4 |
I make Models
Re: bent tailgate
My OEM tailgate had a pretty good bow in it and I removed 95% of it without taking in apart......put the ends on blocks and apply pressure to the center and you can get it to bow back just the way it was originally bowed in the first place.....JMHO.....
05-31-2007, 09:40 AM | #5 | |
Re: bent tailgate
I suppose I might as well give it a try... its better than going without.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
05-31-2007, 12:27 PM | #6 |
Re: bent tailgate
Mine was bent and rusted at the bottom. I cut the bottom off, had a sheet metal shop bend a U from 18 ga. They were not able to get the bend tight enough, so I still had to beat on it to get the radius needed.
The weld seam is under the trim, so my dirt dauber welds are hidden. But I still couldn't figure out how to get to the dents on the top of the tailgate.
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest. 1989 Suburban 1971 Sleekcraft 455Olds Berkeley 1992 SC400 pimp ricer |
05-31-2007, 12:43 PM | #7 |
Re: bent tailgate
Spot welder and slide hammer? That should get the dents out, maybe us a little heat to ease the metal.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-31-2007, 07:43 PM | #8 |
Active Member
Re: bent tailgate
Thanks for the suggestions. It will probably be awhile before I get to it. Worse problems to work on first.
05-31-2007, 07:48 PM | #9 |
Re: bent tailgate
if you have dents on the top then just cut a line in the top widthwise and bend the flaps up a bit and flatten out the dent then put the top back down and spot weld it back and smooth it out, thats what i plan on doing
