Old 05-29-2007, 10:07 PM   #1
'70_402
'70_402's Avatar
Should my volt meter read 0 when key is off?
hey all, long time no post for me. i'm back with a ? i installed a painless wiring harness about 2 years ago and have had no wiring troubles untill now... when i turn my key off should my volt meter go to 0? i think it should, but i have disconnected everything i own on that truck and nothing gets it to 0 other than disconnecting the negitive battery cable..... what gives.... i looked at all my wires and don't have a cut or a bare spot on any of them.... i replaced my voltage regulator and even unhooked the pigtail to the back of the key switch.... any ideas.....
thanks
rick
'70_402 is offline   Reply With Quote
Old 05-29-2007, 10:16 PM   #2
eedgell
It's the air up here
eedgell's Avatar
Re: Should my volt meter read 0 when key is off?
Your saying that it used to go to "0"? With key off?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 05-29-2007, 10:26 PM   #3
'70_402
'70_402's Avatar
thats the thing..... i can't remember.... i might just be freakin myself out.... but my thinking is if i have nothing else on.... why would it be reading 12 or 8 volts.
Old 05-29-2007, 10:22 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if you have a voltmeter, then it is aftermarket, and it needs to get plugged into an acc position in the fuse box.
Old 05-30-2007, 12:03 AM   #5
GREASEMONKEY72
GREASEMONKEY72's Avatar
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 05-30-2007, 01:19 AM   #6
Rupdog
also make sure the door is closed, or the dome light will show current draw. i know it's obvious, but it's also worth mentioning...
Rupdog is offline   Reply With Quote
Old 05-29-2007, 10:30 PM   #7
eedgell
eedgell's Avatar
My after market tach does the same thing in reverse. Stays at 800 rpm untill I turn the key on, then it returns to "0".
Eric
Old 05-29-2007, 10:35 PM   #8
'70_402
'70_402's Avatar
that is understandable.... tachs work that way.... i have all autometer guages and my tach does that, that is not my problem.... i am trying to trace down a wiring gremlin... and i need to know if my theory is correct about the volt meter..... i have it hooked up in the correct spot, in the painless wiring harness there is a wire for the volt meter.
Old 05-29-2007, 10:55 PM   #9
eedgell
eedgell's Avatar
You still never answerd if it used to read "0" before your trouble. Having said that, the meter cant read unless the power is running through it. So with every thing off, power must still be going through the gauge to ground, or flowing. It only reads what "flows" through it. Does your battery go dead? If not it might be a bad gauge.
Eric
Old 05-29-2007, 11:34 PM   #10
Rupdog
off the top of my head, these things draw current when the key is "off"...
1 - aftermarket stereo (memory settings and clock draw current)
2 - dash clock, if installed.
3 - car alarm?
disconnect the negative cable, and put your ohm meter in series between the neg cable and the neg post. if you see current flow, either neg or pos, then pull one fuse at a time out of the fuse box until you see zero battery drain. once you've found the faulty circuit, you can narrow down your search.
someone chime in if i'm soundin' crazy here.
Old 05-30-2007, 12:02 AM   #11
GREASEMONKEY72
kinda sounds fine to me as in when the key is off theres no voltage going through it hence it reading zero and when you turn the key on its got voltage again and reads 12 volts, atlest thats my guess, the gauge in my truck stays in the middle on or off but IIFR the stock gauge is a ammeter and not volt
-steven
Alte Seele S.S.
Old 05-30-2007, 02:53 PM   #12
Longhorn Man
he verified it's an aftermarket volt guage... so all this current talk is moot.
Turn off the ignition, verify your guage says 12 volts or so. Then, disconnect the battery. If it still stays on 12, then the guage is made to do this, like some (not all) tachs as mentioned before.
If it drops, then you'll need to find a switched source to feed the guage.
Old 05-30-2007, 09:10 PM   #13
eedgell
eedgell's Avatar
Sounds right to me Longhorn Man!!!!!
Eric
Old 05-30-2007, 09:52 PM   #14
72lb4x4
Whether or not other things are turned on, such as lights makes no difference to a voltmeter. With 0 volts applied to the meter, it should read 0 volts.
Voltage is applied to a load.
There is no such thing as "voltage going through" a load.
Current flows through a load.
A load draws current based on the resistance of the load.
Think of Electromotive Force, measured in Volts, as water pressure,
current (intensity), measured in Amperes (Amps), as water flowing,
and resistance, measured in Ohms, as restrictions to the flow of water.
E=IR or V=AR, or Voltage=Current*Resistance
From that we get E/I=R, and I=E/R
That's Ohms Law, or a first lesson in DC electric theory without all the thory.
As previously mentioned, the meter should be connected to the accessory side of the ignition switch, since the meter itself is a (very small) load and will draw a tiny amount of current.
If the meter is connected to a power source that's always on, then it should read something as long as the battery is connected. If it reads less than 12V something is loading the circuit the VM is connected to.
If the voltmeter reads 8 volts in a 12 volt system, its possible the battery isn't charged, a load is causing a drop in voltage, or both.
Sorry if that was a rant, but, but, ok, no excuses.
72lb4x4 is offline   Reply With Quote
Old 05-31-2007, 06:22 AM   #15
kbs71
71 rustless in texas
kbs71's Avatar
Yea, what he said
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 05-31-2007, 04:28 PM   #16
neonlarry
neonlarry's Avatar
Did you get Painless to build you a special harness for a voltmeter? Stock type harness would be for an ampmeter. And if you hooked the stock ampmeter wire to a voltmeter it would read 12V all the time.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 05-31-2007, 05:28 PM   #17
airdale94
airdale94's Avatar
Nuff said, I guess.
airdale94 is offline   Reply With Quote
Old 05-31-2007, 06:07 PM   #18
mvfd70
mvfd70's Avatar
My 97 Z71 has a volt meter and it shows zero with the key off. Turn the key on and it reads 12 volts. Start the engine and it reads 13 to 14 volts. I only mention this because I had a cell in my battery go bad the other day and with the key on and engine off it only read 8 to 10 volts. I know this isn't a 67-72 truck but it's the same principle. I agree with others saying that the volt meter should read 0 with the key off. I also agree with the above couple of statements that say that you have a volt meter hooked up to a wire that should be an ammeter. Change the volt meter to a switched power source and/or install an ammeter where you have the volt meter hooked up to now.
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 05-31-2007, 06:11 PM   #19
gator2511
gator2511's Avatar
Voltage does flow through a load. That how we get voltage drops in series circuits.
gator2511 is offline   Reply With Quote
Old 05-31-2007, 08:53 PM   #20
'70_402
'70_402's Avatar
you da man...... like i said to begin with, i couldn't remeber if it went to 0 when the key was off or not..... maybe i just had a battery going bad....
