05-29-2007, 11:48 PM | #1 |
Big Block Cooling?
so here's the deal, im running a 396 with big valve heads, edelbrock alum high rise air gap intake, holley 750 double pumper and mild cam in my 70 1/2 ton. Not to mention a th350 tranny (note:its not an overdrive ) and 3.73's in the back. Im sure this truck is gonna SCREAM at about 70 mph. Does anyone make an electric fan or does anyone know how many cfms its gonna take to cool this thing. I dont think ill have room for a regular fan and clutch along with a electric fan so i really need to be able to just run an electric fan alone......
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
05-30-2007, 12:08 AM | #2 |
Re: Big Block Cooling?
put the manual fan on and put an electric pusher fan infront of the rad on a switch so you can turn it on when and if it needs it, or just run the pusher fan alone but i dont think its gona be at that high an rpm to have to worry about overheating it plus on the highway at 70 you should have plenty of air goin through the rad
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
05-30-2007, 12:13 PM | #3 |
My 69 K20 has with 4.56 gears and heavy 35" tires and an SM465 manual four speed. I don't have any overheating issues and my cruising rpm's at 60 mph are about 2,500. This is with a 1989 carb'ed 454 with a mild cam, stock peanut port heads and ceramic coated headers. I have a 195 thermostat, new 4 core radiator and an Eldebrock aluminum water pump. I haven't made a radiator shroud yet. I use a mechanical clutch fan and do have an auxilliary oil cooler in front of the radiator.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 05-30-2007 at 12:14 PM. |
05-30-2007, 12:22 PM | #4 |
Project Junkie! Fishing Poor!!
Lots of the guys here are running our Duel 12" electric fan assemblies here. I have them on both small blocks and big blocks myself. No overheating problems here. Here is a link to where you can find them on our website: http://www.classicheartbeat.com/radi...&__related.htm WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
05-30-2007, 01:23 PM | #5 |
I think you'll be fine with a regular fan. I have a 396 as well; with a new aluminum radiator, I don't have any heating problems. Just make sure your radiator, fan, and water pump are in good working order and you will be alright.
1968 C10 Stepside 396 bored .030 TH400 |
05-30-2007, 02:46 PM | #6 |
its all about the +6 inches
a mechanical clutch fan is all you'll need.
05-30-2007, 06:45 PM | #7 |
thanks, i guess im just gonna run the stock system with a 4 core rad. i can always add an auxillary fan later if it overheats. Right now i just have the pulley on the pump and dont have a fan/clutch or radiator in and it sure looks like its gonna be a tight fit!
05-30-2007, 08:13 PM | #8 |
Are you running an original short water pump? If so, the stock fan & clutch will fit. If you have the long pump you may not have enough room.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
05-30-2007, 10:24 PM | #9 |
yea, its the short one........thank God
