Old 06-02-2007, 06:58 PM   #1
grady5
air cylinders or air bags
anybody have thoughts on air cylinders instead of air bags?
grady5 is offline   Reply With Quote
Old 06-02-2007, 11:28 PM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: air cylinders or air bags
why bother?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-03-2007, 09:10 AM   #3
royo
royo's Avatar
would you happen to have a pic of a air cyl how do they work compared to a bag
nickle and dime
royo is offline   Reply With Quote
Old 06-03-2007, 11:44 AM   #4
grady5
the reason i asked is i can get them for free and a friend said air bags sway and the cylinders would not. i have never riden in anything with air bags so i dont know either way. i was hoping for some advice. i do not have any pics but he said they would raise the frame just like bags. my guess is it would be similar to the shockwaves but with a piston instead of a bag? plus why not be different i have never seen this done has anybodyhere seen it?
Old 06-03-2007, 01:16 PM   #5
naynay
thats ol skool
naynay is offline   Reply With Quote
Old 06-03-2007, 04:10 PM   #6
smbrouss70
smbrouss70's Avatar
I always thought that air cylinders were to replace struts in cars. I guess it could be done, but you would spend a lot of time making it work.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-03-2007, 07:24 PM   #7
KAILUAZ
King of Rust
KAILUAZ's Avatar
Sounds like a rough ride also. At least the bags act as springs.
1970 GMC 2500, 350, TH400, front disks, thats it!
My Pics
KAILUAZ is offline   Reply With Quote
Old 06-03-2007, 08:48 PM   #8
cajundragger
the cylinders will ride like poo. They dont flex or give at all...I understand the air will compress, but air bags ride so good because of the rubber bag and the air, not just the air.
You can 3 wheel easily with cylinders though.
cajundragger is offline   Reply With Quote
Old 06-03-2007, 09:01 PM   #9
grady5
cajundragger that is the same point i argued with him over. i dont see how they could move either. but he said it could be made to. i dont know. i just thought it might be cool to have something different.
Old 06-03-2007, 10:32 PM   #10
cajundragger
then put it on juice...juice or air bags...cylinders are just weird
Old 06-03-2007, 10:35 PM   #11
grady5
what is juice? hydraulics?
Old 06-03-2007, 11:14 PM   #12
Shane
Shane's Avatar
yes.
Shane is offline   Reply With Quote
Old 06-04-2007, 06:28 AM   #13
grady5
i'm not at all interested in hydraulics. if the cylinders wont work i will use bags.
Old 06-06-2007, 12:01 PM   #14
Kontrol Phreaks
Kontrol Phreaks's Avatar
An air cylinder is primarily used to replace the struts on import cars these days. The mounting type are desinged using a pitch fork lower mount, and the upper plate typically comes with a plate to bolt to a spring tower.
The down side of the cylinders are the overall lenght and stroke that you get out of them. Most of the cylinders out there will provide you with 5-6 inches of travel. That's not much when you you can get 9+ with an airbag in the front of most trucks. The other down side is that an air cylinder rides very poor since it on a small pocket of air. This will sound kinda wierd but it works. You can install a small air tanks (1 or2 gallon) inline between the valves and air cylinder. This will work like an acumalator to help it ride some what better.
I would stay far away from a cylinder as far as installing it on a truck application. It's going to give you a poor ride, limited lift, and make more work for you when it comes to install.
Clint Petree
Kontrol Phreaks is offline   Reply With Quote
