Junior Member
question about my next task...
this weekend, i plan to change the rear oil seal on my TH350. im pretty clear on the actual changing of the seal... but how many quarts of new tranny fluid do i need to pick up?
Crew Cut
Re: question about my next task...
if you use a lift (or jack up level) you will loose less than a qt
85 SWB 1/2 TON CREWCAB/5.3 03 CHEV 3500 DURAMAX CREW CAB 85 CHEV SWB/TPI 06 CHEV TAHOE (WIFES) 30 MODEL A HOT ROD 07 HARLEY DAVIDSON BAGGER 09 STREET GLIDE AN ![]() |
get the @$$ in the air and you won't loose any or very little.
its all about the +6 inches
totallyagree.
Are you swaping out the bushing in the tail shaft too? If not, the seal will probably fail again fairly soon. |
