06-05-2007, 04:47 AM | #1 |
Help with frame z on 67
now that i am almost finished with the rear of my 67 i need to move on to the front. im gonna get the frame z'ed and crossmember raised. how much should i raise both? what problems will i run into with engine placement, tranny placement,steering, and anything else? whats been your experiences? how much did it cost to have done? i already have a quote from the guy that did the rear of the truck but i wanna know what the usual price is.
06-05-2007, 04:51 AM | #2 |
Re: help with frame z.....
i believe you should do them both equally, and i dont think it affects the steering, the engine and tranny will be lifted up and need to be kept level with each other but other than that im not sure
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-06-2007, 12:45 AM | #3 |
ttt.....
06-06-2007, 11:49 PM | #4 |
i forgot to mention that in the beginning i will be running 215/75/15 white walls. then i might switch to 18x8 smoothies. back to the top this goes.
06-07-2007, 12:07 AM | #5 | |
How much did he quote you? What exactly (in writing) will he be modifying?
06-07-2007, 12:20 AM | #6 |
he quoted me $800 to z the frame,raise the crossmember, install the bags,fittings,valves and copper line for the front. yes i am happy with the work he did before.
06-07-2007, 12:40 AM | #7 |
A guy with a truck
Sounds like a fair deal to me if he does good work. There is a lot of hard labor involved in all of this. Does he know what he's getting into?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-07-2007, 12:43 AM | #8 |
That's an understatement.
06-07-2007, 12:45 AM | #9 |
That's a lot of work for $800! If you have dealt with him in the past and have been pleased with the quality of work then he's your man.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-08-2007, 11:34 AM | #10 |
Re: Help with frame z on 67
why copper line?
we were just talking about this and how it has a low tolerance for heat and it's softer. why not run stainless hardline?
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
06-29-2007, 07:30 PM | #11 |
soon to be bagged64sub
I Zd mine myself 2 3/4" and would def. pay someone I trusted $800 to do it.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
06-30-2007, 03:48 AM | #12 |
$800 sounds cheap If you ask me theres a bit of work
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN 62 HARDTOP NOVA 65 CHEVROLET BB LWB FLEETSIDE 90 CHEVROLET EXTRA CAB CHEVY ONLY - NZ Chapter http://67-72chevytrucks.com/vboard/s...d.php?t=137984 |
06-30-2007, 09:05 AM | #13 |
Sorry to highjack the thread, but may i ask what z-ing the frame is?
06-30-2007, 09:11 AM | #14 |
Nevermind i found it. Why do you z the frame instead of body drop the truck?
06-30-2007, 11:05 AM | #15 | |
'Tohmayto', 'Tuhmahto'..... They both accomplish similar results & there's alot of work involved either way you go.
