Old 06-07-2007, 10:42 PM   #1
killer71
killer71's Avatar
Killers 5.3L install
Well, this is as close to installed as the boy and I could get, so I loaded Killer up and took er up the road to 68 short steps house. Says he can hooook it upppp!!!! So give em a shout when yall are ready for progress pictures
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-07-2007, 10:48 PM   #2
71chevylowrider
71chevylowrider's Avatar
Re: Killers 5.3L install
Now that is cool! I love it!
71chevylowrider is offline   Reply With Quote
Old 06-07-2007, 11:15 PM   #3
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
Change the intake gasket before the install. I replace them all the time due to vacuum leak cuasing lean codes (P0171 AND P0174). Good luck and thats a clean looking truck.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 06-07-2007, 11:40 PM   #4
68 short step
the truck is extra nice... the frame ( and truck in general) is much better then expected... but you know how these prokects go, you start off with a engine swap, then it leads to a frame off restoration.... so next week expect to see some progress pics...
68 short step is offline   Reply With Quote
Old 06-11-2007, 07:14 PM   #5
68 short step
started to tear the engine apart, and this thing is spotless.......also started the rewiring process... heres the pics of how it came and the original wiring harness... and the engine internals
Old 06-11-2007, 07:24 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
Did you pull it all the way from Louisiana to Dallas with the John Deere?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-11-2007, 07:26 PM   #7
killer71
killer71's Avatar
I probably would have made the same timing...2 different stops for flats..go figure?
R.I.P.
Killer 71
10/26/07
Old 06-11-2007, 08:32 PM   #8
sb69chevy
sb69chevy's Avatar
That is SO awesome. Can't wait to see this installed.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 06-11-2007, 10:22 PM   #9
72CSTC5
72CSTC5's Avatar
I am thinking of doing the same thing. I have access to the same motor and trans for CHEAP!! It only has 16,000 miles.
72CSTC5 is offline   Reply With Quote
Old 06-11-2007, 10:26 PM   #10
killer71
killer71's Avatar
You better grab it!
R.I.P.
Killer 71
10/26/07
Old 06-11-2007, 10:56 PM   #11
72CSTC5
72CSTC5's Avatar
Are you guys running the 4l60E computer trans in these things too?
Old 06-11-2007, 11:02 PM   #12
68 short step
yelp
Old 06-11-2007, 11:01 PM   #13
killer71
killer71's Avatar
Yep!
R.I.P.
Killer 71
10/26/07
Old 06-11-2007, 11:25 PM   #14
shifty
Questionable
shifty's Avatar
damn, that is a new freaking engine alright. but why you take off the pan and tray? are there plans for a buildup already?!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-11-2007, 11:27 PM   #15
killer71
killer71's Avatar
It's a surprise. I owe you for directing me to the right people for the motor, and I thank you for the info.!
R.I.P.
Killer 71
10/26/07
Old 06-12-2007, 06:47 AM   #16
Hart_Rod
Hart_Rod's Avatar
I like suprises, .
Hart_Rod is offline   Reply With Quote
Old 06-12-2007, 08:27 AM   #17
69Custom
69Custom's Avatar
Good luck with swap, got to love the all aluminum engine blocks. I got one out of a SSR with less than 1000 miles for $1000 two years ago.
Just as a warning, I am not sure if the block is the same as the SSR, but the dip stick for these engines are in the oil pan. When you swtich to the truck pan, it uses a dipstick in the block. You can locate and drill.
1972 Chevy C-10 Short Stepside
6Cyl, 3 spd, not opts
(Current Project)
Now a 2004 SSR 5.3L with 4L60E
Now Ididit tilt- ps, pb
2002 Saturn L200
2006 Toyota Highlander HYBRID
69Custom is offline   Reply With Quote
Old 06-12-2007, 11:06 AM   #18
shifty
Questionable
shifty's Avatar
did you actually need to do this? I got an LS1 out of a car, tossed on a oil pan from a truck, and you must replace the oil pickup, dipstick tube, dipstick and windage tray to adapt - the OEM dipstick tube and dipstick come bundled together, same as the oil pan and windage tray - and the truck dipstick tube plopped right into the car dipstick hole without a problem - simply used a different bolt hole to mount the dipstick (alternate hole was factory provisioned and tapped into the head)
Curious if this is not the case with the SSR or TB SS engines
Old 06-11-2007, 11:40 PM   #19
68 short step
shifty please read your entire thread, most your questions are already answered....J/K the trailblazer pan needed to be switched to the truck pan to clear eveything...
Old 06-11-2007, 11:58 PM   #20
killer71
killer71's Avatar
Now that's some funny s#^t!
R.I.P.
Killer 71
10/26/07
Old 06-12-2007, 11:03 AM   #21
shifty
Questionable
shifty's Avatar
Aha! I didn't realize this came out of a TB SS. maybe i should have read the whole thread!!
Old 06-11-2007, 11:40 PM   #22
72CSTC5
72CSTC5's Avatar
Killer, how many miles were on yours?
I have to say 68's motor up close is amazing in his truck.
Old 06-11-2007, 11:54 PM   #23
killer71
killer71's Avatar
5....he's primping mine up to look like his!
R.I.P.
Killer 71
10/26/07
Old 06-12-2007, 12:38 AM   #24
oscareltemblo
oscareltemblo's Avatar
Awesome build gotta love the lsx motors.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
oscareltemblo is offline   Reply With Quote
Old 06-12-2007, 10:08 AM   #25
Chevy_Man
Tightwad
Chevy_Man's Avatar
Hey Killer......i see you got the truck and motor ready fro me to pic up to come to my house........lol i wish.... i want to see this build..I found one in the paper that only has 150 miles on it and all the wiring is with it but minus the tranny for $2000.00 i was hoping it came with the tranny too but he said he was going to keep it...It came out of a 05 3/4 ton chevy van....Wish i had the funds to get it....What all does this swap involve?
This was the add that i had found and i have ben emailing the guy about it...
Vortec 275 horse 4.8l. engine for sale w/ 120 mi.
2005 4.8 l. 275 horse chevy vortec v8 eng. w/ 120 original miles.Will sell with all acc.(air,p.s.,alt.,etc.) inc. computer and harness $2450. eng and harness only $1950!! Individual selling! call or email !
Is this bad?
Eric
56 Chevy custom cab step side under construction
55 Chevy 210
68 SWB Stepside back burner under construction
72 Chevy LWB
84 CJ 7
05 Chevy 1500 Crew Cab
30X40 DOGHOUSE(shop) with many add ons
Chevy_Man is offline   Reply With Quote
