![]() Join Date: May 2007
TH350 leak and NP205 leakier. HEELLPPP!!
I just realized I guess I should have put this in the general discussion stuff on trannys and t-cases. Well I'll post it there too. I hope thats not bad manners.
Re: TH350 leak and NP205 leakier. HEELLPPP!!
Sounds like your leak may just be because it sounds like you are missing the dipstick. You can buy these at any parts store for like $10-20 bucks. there will be a hole just opposite the front corner passenger side of the the tranny. if you are laying underneath it looking up reach over that corner and you should find the dipstick rod or a hole where it use to be.
hope that helps
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
I've got the dipstick I just wasn't sure if I poured fluid down that little hole if it would cause a problem as it is it is the only spot I can see to fill it.
- Jason ![]() ![]() |
Designated A-hole!
That's where you fill it, the dipstick tube.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
THat makes me feel dumb. Cool well krue I owe you another one. Also I joined up as a supporter. Thanks again for all the help.
![]() Join Date: Feb 2000
It's money well spent
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Designated A-hole!
We appreciate your support, and anything I can help with let me know. If you wanna do some interesting reading, click the Index link in my sig.
GEARHEAD
The tranny will and should be warm from even a short drive. You just need to keep it from getting too warm and that means over about 200F. The tranny cooler built into the radiator is done that way to help the fluid warm up when cold. This is more of a feature for northern climates, but they are all done the same. In fact, you don't need to use the radiator tranny cooler if you don't want to. I converted my truck from manual tyranny to auto and used an add on tranny cooler for several years, until I had some radiator work done, then they added the cooler tank to my existing radiator.
If your pan gasket leaks and you are not sure about the history of oil changes, etc. Take the truck to the local oil change shop or garage you use and have them replace the tranny oil filter. They have to pull the cover and will install a new pan gasket when they do it. The cost is usually not bad. Like $75 around here.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#10 | |
Just my two cents |
