Old 06-08-2007, 12:56 PM   #1
one9six9
Junior Member
Disc Brake Proportional Valve
Will the proportional valve from a non-power brake system work with a power brake system?
Can I just install a booster behind the non-power master cylinder?
I am installing a disc on my 69, and I am also going with power brakes. I have a master cylinder and prop. valve from a non-power 71.
What do I need to complete this task?
Thanks,
Keith
one9six9 is offline   Reply With Quote
Old 06-08-2007, 01:25 PM   #2
68speedalert
Semi-Senior Member
68speedalert's Avatar
Re: Disc Brake Proportional Valve
In theory, it shouldn't matter with the prop valve if it's power or not. The ports from the M/C have to installed correctly; smaller sized resevoir goes to the rears, larger goes to the front brakes. They've got to go to the right port on the prop valve.
I wouldn't have thought that the M/C would not be the same, power vs. non power, but NAPA only shows one M/C regardless of the option.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
