Old 06-11-2007, 10:04 AM   #1
swb85
On a budget like Fred Sanford
swb85's Avatar
easy A/C question
I'm trying to piece the a/c back together on my '85, and I've got it all figured out except the compressor wiring. The harness I have has two green wires that run from a plug on the firewall down to the compressor. The first green wire goes to one side of the dual spade plug on the compressor (I assume it's the power wire), the other side of the spade plug is a black wire to a ground.....that part's easy.
My problem: The second green wire coming from the firewall is the part I'm stuck on. I have no idea what it is or where it goes! It's got a spade connector on it. Help!!!! Anyone feel like going out and looking at their a/c wiring?
Edit: Here's a picture of the plug on the firewall I'm talking about:
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 06-11-2007, 10:38 AM   #2
Jonboy
Slots go on anything!
Re: easy A/C question
IIRC, there is a harness that goes along the left valve cover that plugs into the compressor and temp sender, and plugs in there. It has been a while since I have worked on one of those, so my memory may be a bit foggy.
The temp sender wire is green also. That has stayed constant through the years.
Jonboy is offline   Reply With Quote
Old 06-11-2007, 10:47 AM   #3
swb85
swb85's Avatar
Thanks for the reply! I've already got my temp sender wire though, so it's gotta be something else.
Old 06-12-2007, 09:40 AM   #4
swb85
swb85's Avatar
Anybody wanna take a quick look at their a/c wiring for me?
Old 06-12-2007, 06:31 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
Maybe these will help? This is on a 77. One wire is dark green and the other is green with a black stripe. The dark green one goes to the compressor.
Pyrotechnic is offline   Reply With Quote
Old 06-12-2007, 08:39 PM   #6
pcmcobra
pcmcobra's Avatar
on my 86, is the same as pic above. Dark green goes to compressor.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-12-2007, 10:29 PM   #7
swb85
swb85's Avatar
Thanks guys! And the light green wire?? The light green wire is the one I'm having trouble with.
Pyro: It looks like you don't even have the light green wire hooked up.....does your a/c work? If the a/c works fine without it, that's all I need to know!
Old 06-13-2007, 08:33 AM   #8
Pyrotechnic
A/C works great. The truck is mostly unmolested so I'm pretty sure thats factory wiring.
Old 06-13-2007, 10:15 AM   #9
swb85
swb85's Avatar
Works for me!....Thanks!!
