06-12-2007, 08:24 AM | #1 |
Rottenwood Garage Member
I want to make a dually out of a long bed.
I need to know from what vehicle I can rob the dually rear end out of that will work under a stock long bed 67-72. I believe it needs to be narrower than a stock dually...like a gruman van or something.
Does anyone have any info on this?????????? Thanks |
06-12-2007, 08:33 AM | #2 | |
72 C30 Trailer Queen
Re: I want to make a dually out of a long bed.
Cab/chassis trucks from 67 up to 91 (old body 73-87 style) will have rear ends that will work as far as leaf spring spacing. You will have to modify your inner wheel tubs in the bed to run a cab/chassis dually rear. One drawback to this is that you no longer have 4 feet between the tubs; something to think about if hauling sheet goods.
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts Last edited by Chris H; 06-12-2007 at 08:37 AM. |
06-12-2007, 08:51 AM | #3 |
you could something like this, he used stepside fenders and extended them down.
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com Last edited by 1lowdiesel; 06-12-2007 at 08:51 AM. |
06-12-2007, 10:07 AM | #4 |
06-12-2007, 07:23 PM | #5 |
The LuvShack Garage
I like it
06-12-2007, 05:56 PM | #6 |
its all about the +6 inches
that's my plan too, but I want to cut it so it is narrower in front.
06-12-2007, 06:09 PM | #7 |
That is a cool truck but it needs two more doors to be just right!
Kevin LFD Inc. |
06-12-2007, 06:29 PM | #8 |
i,ve got a factory dual wheel rear end, 4.10 ratio, ho 72 eaton. 300.00
bob in tn. |
06-12-2007, 06:50 PM | #9 |
Currently Blazerless
Heres a few pics of my bed, the 14 bolt rear I am using is a standard 1 ton rear so its a little wider than a cab and chassis rear. Mine uses the stepside fenders and has been tubbed, I'm in the process of changing to the larger 3 1/2" brake shoes for much better stopping power.
I may also switch to cab & chasiss hubs to tuck the tires in 2" more but I'll have to wait and see how the tires fit when its back together.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 06-12-2007 at 06:50 PM. |
06-12-2007, 10:47 PM | #10 | |
I would love to see a profile shot of the side of your bed, just want to get an idea of how wide your step-dually-side fenders look from the rear. Is this the one that is getting the new wheels??? That is going to look great!
Chris H 72 C30 133" 72 C30 157" flat-dump 69 C10 short fleet 71 ElCamino 2000 K2500 crewcab shortbed (sold, sorry old friend) 2005 GMC 2500HD shortcrew Duramax 2006 K1500 RCSB and a couple other projects/parts |
06-13-2007, 09:39 AM | #11 |
that's sweet very clean.
what wheels you goin with?
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
06-13-2007, 07:04 PM | #12 |
The wheels are American Alloys in 19.5 x 6 and the tires are Cooper 8R C-140s
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 06-13-2007 at 07:05 PM. |
06-13-2007, 07:09 PM | #13 |
The LuvShack Garage
06-14-2007, 12:22 AM | #14 |
Epoxy Primer Friendly
The best C10 Dually ever thanks to GRANT
