Old 09-16-2002, 08:24 PM   #1
bamaK5
Dana 20 Transfer Case
I was going to change the front pinion seal out in my transfer case the other day and I ran into a problem. I got a 3-speed trans w/ and transfer case out of a 1969 K5. I thought the transfer case was a Dana 20, and that is what I have been told. But when I got to the parts store to get the seal, they only showed one for a Spicer 18 and the Rockwell. I saw the Federal Mogul book myself, so the guy just didn't miss it. Can somebody please help me out. Thanks in advance!!!
Chad Borden
1971 K5 Blazer 307 3sp/205(project)
bamaK5 is offline   Reply With Quote
Old 09-17-2002, 07:35 AM   #2
Blazer1970
Blazer1970's Avatar
Federal Mogul book is wrong, plain and simple. Spicer 18 is similar to the Dana (Spicer) model 20, except the 18 has an offset rear output. You may have to get the number off the seal that is in there. Good chance that it is the same seal as a model 18.
Blazer1970 is offline   Reply With Quote
Old 09-26-2002, 01:13 AM   #3
diehardrider
KEEP IT PINNED
Ive never heard much about the rockwells.
Anybody know anything about them?
RYAN KING
71 swb 4x4
diehardrider is offline   Reply With Quote
Old 09-26-2002, 03:49 AM   #4
Pont
I need another Barley Pop
Pont's Avatar
Ryan, I have a Rockwell in my truck. The number one thing I like most about it is that the output for the rear driveshaft is at the very bottom of the transfer case. That helps from having too much driveshaft angle with my 8" lift. Other than that, I don't know much about them. Mine works great!
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 09-26-2002, 10:31 AM   #5
Yukon Jack
Yukon Jack's Avatar
I've got one in my 69 and parts are kinda hard to find and expensive. I'm pulling mine shortly when I put in a 4 speed and 454 so I have purchased seals for it. Couldn't find a gasket kit so I will just make them and/or use silicone. They are plenty strong but just not very desirable because of lack of parts and knowledge about them.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-26-2002, 02:03 PM   #6
diehardrider
KEEP IT PINNED
Oh ok. Ive never seen one before that i know of.
Thats interesting about the output being lower. That should be nice.
At least they seem to be a strong unit and dont need to many part to be replaced. Seems like and old transfer case is plenty strong.
Do some have a pto?
Is it the same rockwell company that makes the 2.5 ton axles?
RYAN KING
71 swb 4x4
Old 09-26-2002, 02:11 PM   #7
palallin
Yes, there is provision for a PTO, and, yes, it is the same Rockwell. In fact, they were used on some Mil-Vehs.
Someone posted a link to a T-case specialty place a couple weeks ago that stocks Rockwell parts and seals. I don't have it saved here at work.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 10-13-2002, 10:03 PM   #8
Rod
4x4 parts for your transfer cases
Dana's, Rockwells, NP205 what ever.
http://www.drivetrain.com/transferca...%20Model%20205
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
