06-16-2007, 12:44 AM | #1 |
Large invetory of parts
This is an inventory of my 67-72 Chevy truck parts. I have not included all the small items. I will combine shipping if you buy several items. I will ship the large or heavy stuff DHL ground(no PO Box) USPS for small items. I can send or post pictures if requested.
Paypal, cash or M/O. Please respond here. Thanks The first # is year removed from and second # is year it will fit. The price is the last # and the quantity I have is the 2nd to last #. Prices are for each or for the pair. Sorry for the mess but this format slides it all over to the left . YR/MOD YR/MOD ASKING REMOVED FIT DESCRIPTION QTY $$$$ 72 67-72 DRIVERS INNER FENDER BRACE (DRIVER) 2 $5 72 67-72 WHIPER BOTTLE BRACKET (PITTED) 1 $4 UNK 67-72 VOLTAGE REGULATOR 3 $5 VAR 67-72 HORN W/ BRACKET 2 $5 69 67-72 COIL SPRING HOLD DOWN BOLTS W/ RETAINERS ST $5 70 67-72 Z-BAR BRACKET (HOLES BLOWN) 1 $5 72 71/72 HOOD LATCH 1 $7 SOLD 72 67-72 EXTERIOR DRIVERS DOOR LATCH 1 $12 VAR 68-72 SIDE MARKER LNSES (ORANGE) 2 PR $4 ea 72 69-72 CUSTOM/20 BADGES PR $12 UNK 67-72 STEPSIDE TAILGATE CHAINS (SURFACE RUST) PR $8 VAR 67-72 STEERING COLUMN ANTIROTATION BRACKET 2 $4 69 67-72 TAIL LIGHT HOUSING PR $12 70 67-72 TAIL LIGHT HOUSING (SURFACE RUST) PR $6 UNK SBC PS PUMP BRACKETS AND HOSES 1 $45 70 69-71 BLACK ARM REST 1 $8 70 67-71 REAR VIEW MIRROR W/ BRACKET (HAZY) 2 $8 72 67-72 A/C HEATER CONTROL (1 BROKEN LEVER) 1 $25 76 74-80 A/C HEATER CONTROL 1 $15 UNK 74-80 FULL TIME T-CASE SHIFTER/KNOB (PITTED) 1 $10 70 67-70 PLASTIC GAS PEDAL 1 $5 72 67-72 DOOR STRIKERS W/ SHIMS PR $7 72 67-72 STEERING COLUM COVER 1 $4 UNIV SHIFT KNOB CHROME AFTERMARKET 1 $5 70 DANA 44 CLOSED KNUCKLE 3.08 FRONT AXLE 1 $100 70 12 BOLT 3.08 OPEN REAR AXLE 1 $100 70 DANA 44 OPEN KNUCKLE 3:73 FRONT AXLE 1 $100 UNK UNK 1 PIECE DRIV SHAFT 76 1/4'' OVERALL 1 $20 72 67-71/72 WHITE PASS DOOR 1 $65 VAR 67-72 COWL PANEL 3 $15 72 71/72 OUTER GRILL, SMALL CUT ON DRIVER SIDE 1 $30 UNK 71/72 GRILL, CUSTOM INSERT, DENTS 1 $50 UNK 67-72 A/C DASH ASSY 1 $40 70 69-72 HOOD, NO DENTS OR ROT 1 $40 72 HO52 HO52 F/F AXLE SHAFTS PR $35 72 71-72 C20 SPINDLES ST $30 72 71-72 C20 CALIPERS ST $30 72 71-72 BACK PLATES ST $20 72 71-72 ROTORS 8 LUG (NEED SLIGHT TURNING) PR $30 $100.00 FOR DISC SET UP 72 71-72 C10 SPINDLES ST $30 72 71-72 C10 CALIPERS ST $30 72 71-72 BACK PLATES ST $20 72 71-72 ROTORS 5 LUG (NEED SLIGHTTURNING) PR $30 $100.00 FOR DISC SET UP 72 HO52 HO52 F/F DRUM 1 $25 72 67-72 STEERING COLUMN (MANUAL) 1 $30 69 67-72 REAR SHOCK MOUNTS ST $10 70 67-72 CAB WINDSHIELD UPPER FRAME PATCH 1 $35 70 67-72 RADIO PATCH NON A/C 1 $15 70 67-72 TRANNY CROSS MEMBER (MANUAL) 4X4 1 $20 70 67-72 TRANNY CROSS MEMBER (AUTO) 4X4 1 $25 70 67-72 ENGINE CROSS MEMBER 4X4 1 $30 70 67-72 CLUTCH/BRAKE PEDAL HOUSING 1 $25 70 67-72 CAB MOUNT FRAME BRACKETS ST 1 $5 70 67-72 FRONT LEAF SPRINGS W/U-BOLTS, SHACKLES ST $40 UNK UNK ENGINE TO TRANNY METAL COVER 1 $10 UNK 67-72 HEATER BOX (INSIDE) W/ CABLES 2 $20 UNK 67-72 WHIPER ARMS ST $10 UNK 67-72 FRONT BUMPER BRACKETS ST $20 UNK 67-72 TRIM (STRIP BEHIND CAB) 1 $10 UNK VAR TH350 SHIFT LINKAGE WITH ROD (NO FRAME PIECE) 1 $15 SOLD UNK VAR TH400 SHIFT LINKAGE WITH ROD (NO FRAME PIECE) 1 $15 UNK 67-72 PARKING BRAKE HOUSING/CABLE SET UP (LWB) 1 $25 71 71-72 GRILL H-LIGHT RINGS AND BEAZLES ST $15 UNK UNK SPEEDO CABLES 2 $5 UNK 67-72 FUSE BLOCK AND HARNESS (SOME CUTS) 1 $15 UNK VAR VAR STEERING WHEELS 2 $10 UNK 67-72 RUBBER HEATER DUCTS UNDER DASH ST $5 UNK UNK FULL TIME T-CASE SHIFT COVER AND MARKER 1 $10 UNK VAR 3" LIFT BLOCKS PR $10 SOLD UNK 67-72 6 CYL ENG TOWERS PR $15 UNK SBC ROCHESTER Q-JET 2 BANGER (COND UNK) 1 $15 UNK 67-72 MASTER CYLINDER (NO POWER) 1 $10 UNK 67-72 HEATER/AC BLOWER MOWER 1 $5 UNK VAR 4 BRL SNORKLE AIR CLEANER 1 $20 72 67-72 OVERLOAD SPRINGS ST $25 SOLD UNK 67-72 WHIPER MOTORS 2 $10 UNK SBC ALTERNATOR (INTERNAL REGULATOR)NEW 1 $25 NA NA 7 1/2 TON D-RINGS 3 $10 NA VAR PRO COMP STEER/STAB MOUNT KIT (NEW) 1 $15 UNK UNK ALTERNATOR (NEED TO FIND APLICATION) 1 UNK UNK GEAR REDUCTION STARTER (NTF APPLICATION) 1 UNK SBC LONG WATER PUMP 1 $10 UNK 305SBC H BALANCER 1 $10 UNK SBC BALANCER CRANK PULLEY (LONG PUMP) 1 $10 UNK 67-72 DASH CLUSTER/BEAZLE W/OUT GUAGES 2 $20 UNK SBC EXHAUST MANIFOLDS (NOT RAM) ST $20 69 69-72 REAR PANARD BAR 1 $15 UNK 67-71 WINDOW REGULATOR 1 $15 UNK 67-72 DRIVERS DOOR LATCH, LEAVER AND RODS 1 $10 UNK 67-72 DRIVERS GLASS RAIL W/ BAD FELT 2 $5 UNK 67-72 DRIVERS GLASS CLEAR 1 $5 UNK 6 LUG 4X4 CENTER CAPS 6 LUG 2 $10 UNK SBC ALUMINUM VALVE COVERS ST $15 UNK SBC ALUMINUM VALVE COVERS ST $10
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins Last edited by WORNBRAKES; 06-22-2007 at 06:58 PM. |
06-16-2007, 01:19 AM | #2 |
Re: Large invetory of parts
I'll take the 4" lift blocks for $10 plus shipping to 30047 let me know I'll paypal you and if the shift linkage with rod is from a 4x4 i'll take it also thanks Mike
06-16-2007, 06:27 AM | #3 |
The LuvShack Garage
WOW, are you coming to the Board Meet?
06-16-2007, 06:43 AM | #4 |
Chevy Freak
I'm interested in the sbc alum valve covers (both sets), but I'd like to see pics. Brian
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
06-16-2007, 11:21 AM | #5 |
Interested in coil spring hold down bolts and retainers. I assume they are for the rear and condition of bolts and retainers? shipping to 50588 Iowa
06-16-2007, 11:25 AM | #6 |
I'm interested in the better of the 2 wiper motors.
06-16-2007, 11:25 AM | #7 |
Can I get a pic of the 71-72 grill?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
06-17-2007, 04:12 PM | #8 |
LUV- I wish I could make it up there for the meet. I was just up in Springfield last weekend for a family reunion and my job won’t let me off for the meet. I look forward to being at the next one.
Mike- I pulled the lift blocks out today and they are 3” not 4”. If you still want them, USPS flat rate for 9.00 is the best for the weight. Both shift rods come off the 2 4x4’s I parted. If you want that as well, DHL ground is 11.00 for the blocks and shift rod. Please let me know if you want the 350 or 400 rod. Brian- here are some pics. Solver- Shipping is 8.00 for DHL ground or 9.00 for USPS flat rate or 6.00 for USPS standard. I pulled them out and the reason I marked them at 5.00 is because 1 of the cups is missing and the PO used a piece of metal. See pic. Lowrider- USPS flat rate for 9.00 is best to ship the wiper motor. Jorge- There are some pics and a good description in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=236396 If you are interested, PM and let me know how you would like to pay and I will send you payment info. Thanks
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
06-17-2007, 09:05 PM | #9 |
Chevy Freak
I'm going to pass on the valve covers. Thanks. Brian
06-17-2007, 11:37 PM | #10 |
How complete is the wiring harnes?
would be interested depending on condition and completeness. Thanks, Steve |
06-18-2007, 02:30 AM | #11 |
Location: Sunny, Florida, some might call it South Alabama
I didn't see it listed, but I just had to ask, you don't have a 71-72 rear end do you?
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
06-18-2007, 08:32 AM | #12 |
Is the "manual" steering column for a floor shift or 3 on the tree? Condition?
06-18-2007, 10:57 PM | #13 |
Steve- the harness is only missing the connector for the rear tail lights on the firewall. Otherwise it is complete. I got another one tonight but it is missing the connector for the ignition.
smoky-I have a few rear ends. Confirmed I have (2) 12 bolt leaf rears, 1 3.08 and the other 3.73. I also just pulled in a 3/4 ton truck this weekend with a HO FF coil axle. I have not had the chance to pull the cover and look at it. I will be pulling another 1/2 ton truck in this week and I believe it has a 12 bolt coil. Again, I will have to look at the condition and ratio. I have not done any freight yet but I am up for it if you have some information on where to start. Or I can keep it untill you can get up here. jdstx-The column come from a 4 speed on the floor truck. It seems to be in good condition but has no shaft to connect to the rag joint. Thanks
06-19-2007, 01:49 PM | #14 |
PM sent
06-19-2007, 04:47 PM | #15 |
Could you please tell me how far you are from Dallas? I am interested in the UNK UNK 1 PIECE DRIV SHAFT 76 1/4'' OVERALL 1 $20 .... thanks...
06-19-2007, 10:18 PM | #16 |
noah- I am 20 miles East on I 30 from the I30/I635 mixer.
06-20-2007, 07:46 AM | #17 |
I'll take the column if I can manage to pick it up. I am traveling to East Tx on Sunday(24 June). I may be able to swing up your way that afternoon, if that will work for you, let me know and we will arrange it.
06-20-2007, 02:15 PM | #18 |
jdstx-PM sent
06-21-2007, 04:18 PM | #19 |
PM sent with a couple of questions
06-21-2007, 04:29 PM | #20 |
interested in the radio patch for 15$ what would the shipping be to temple, tx 76504? Thanks.
06-21-2007, 04:36 PM | #21 |
Did I see an air dash assembly let me know shipping to 15010
69 cst 10 396/th400 12bolt fact air buckets console spotlight and cut in bed steps 64nova ss 406/th350 69 Lincoln markIII |
06-21-2007, 07:26 PM | #22 |
Can I see some pics of the steering wheels you have? I would be interested in one from 67-72 if you have it.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
06-21-2007, 10:12 PM | #23 |
Having issues
I need a 292 power steering setup, and 4" lift springs (4wd) Any leads on those?
06-21-2007, 10:55 PM | #24 |
Thealien-PM'd you back. Pics of the caps and some other parts can be seen here:
http://67-72chevytrucks.com/vboard/s...d.php?t=232022 bean- shiping DHL G is 8.00. Pic here: http://67-72chevytrucks.com/vboard/s...d.php?t=238129 1969bb-DHL G says 20.00. Pics and description here: http://67-72chevytrucks.com/vboard/s...d.php?t=236380 st1x10- pics of wheels I have are here. I pulled one from my 69 that is orig but it has several crackes. 5.00 for that plus shiping. Pics of others are here. The only one I have right now of the other wheel is in my other thread for parting 69 c20. http://67-72chevytrucks.com/vboard/s...d.php?t=232022 beavis- I cant help but I will keep my eyes out for you. Thanks
07-12-2009, 10:03 PM | #25 |
How much for the 4x4 automatic trans crossmember?
