Old 06-18-2007, 07:05 AM   #1
60ratrod
yes, i do
60ratrod's Avatar
chevy 350 rocker arms
hi guys, i'm new to this forum sight, but not to the automotive world. so here's my problem. i have a chevy 350 in my 60 c10 and have been having a few problems with my valve train since i swapped to roller rockers. i think that a few of my rocker arm nuts keep backing off. but my question is when i go to adjust my rocker arms when the motor is off and cold, is it normal for a rocker arm to loosen up after i adjust it?? i'm getting ready to swap my rocker arm nuts for the type that have the set screw in the top and the last 2 times that i have adjusted my rocker arms i find that i have a few that are loose after i adjust them. any thoughts?? photos to come later.
60ratrod is offline   Reply With Quote
Old 06-18-2007, 07:19 AM   #2
Back in Black 66
Back in Black 66's Avatar
Re: chevy 350 rocker arms
just make sure the studs arent being pulled out of the casting its a really common thing and it will seem like the rockers will loosen up. if the are pressed in studs they will do that thats why i always switch to bolt in instead. the bolt in will have little nuts that are part of the stud just above the casting of the head. look carefully and see if they are bein pulled out and that might be the problem.
Back in Black 66 is offline   Reply With Quote
Old 06-18-2007, 02:09 PM   #3
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
fm. Galveston,Texas
gulfcoast66 is offline   Reply With Quote
Old 06-19-2007, 12:03 AM   #4
60ratrod
yes, i do
60ratrod's Avatar
thanks gulf. how can i tell if the studs are pulling out?? i didn't build this 350. i just kinda took over a started project.
Old 06-21-2007, 08:08 PM   #5
Billla
Billla's Avatar
The quick and dirty way is to pull the rockers and just lay a straight edge across the top of the studs. You'll see it right away if you have a problem
What kind of "problems with the valvetrain"?
Billla is offline   Reply With Quote
Old 06-21-2007, 06:29 PM   #6
bills67
bills67's Avatar
If you have hydraulic lifters, they'll collapse and feel loose again after initial adjustment. Adjust them once and go with that, once engine is running they'll pump up with oil and will be solid. I made the same mistake and ajusted them twice, when it was time to start motor I had a hell of a time because I over adjusted, and the valves weren't closing all the way. Went back loosened them all, adjusted once, engine fired right up.
67 Chevy C-10 LWB Fleet
95 Chevy Silverado Z-71
bills67 is offline   Reply With Quote
Old 06-21-2007, 07:17 PM   #7
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
I've always done my fine adjusting with the engine running, a little messy but it has always given me the best results. Jerry
ClassicAutoResto is offline   Reply With Quote
