06-18-2007, 08:20 PM | #1 |
Noobie McNoobster
Master to Prop valve lines
Anyone know what size the lines are supposed to be that go between the master cylinder and proportioning valve? Truck in question is a 1968 with 1972 brakes. Here is what I have now, the drum side seems to be bigger than the disk side.
Here is a pic of what I have now.
The Stable: 1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes 1990 Chevy V2500 Suburban 2005 Kawi KLR650 1983 Honda Goldwing GL1100 Standard (Naked) 1995 Miata M Fortes Fortuna adiuvat |
06-19-2007, 09:08 AM | #2 |
Re: Master to Prop valve lines
Thats the way they are, drums need high volume/low pressure (large size lines) and the disk side needs low volume/high pressure (small lines)
06-19-2007, 02:14 PM | #3 |
Noobie McNoobster
Thanks, that was what I thinking, I am getting ready to rebuild all the brakes in the truck (Master Cyl, WHeel Cyl, Calipers, soft line and etc) and just wanted to see if I should look at replacing the hard lines as well.
06-19-2007, 02:23 PM | #4 |
Licensed to Thrill!
Just a question - I knew this before doing my setup - but went ahead with the all 3/16" line to the prop valve anyhow.
Is this going to matter? My line to the prop valve is longer than most...(from there on it is 1/4" just like normal). My prop valve is on the frame, so I have a little more line there. I don't know if it is going to hurt anything, but just wondering if anyone might know for sure. DLB |
