06-21-2007, 11:59 PM | #1 |
Straight "6" Shooter
Color Combos
What were the color combinations on the 64-66 c-10s. I think mine used to be white, and a reddish brown trim. I have seriously been thinking about going back to the original colors, since they wouldnt look bad. My poor truck has had about 7 different coats of spray on paint over the years. I was in the middle of sanding it, and some of it chipped off, and was white. I scrathed a bit further, and found 5 more layers of paint, and then white again before the metal. It may also have had some weird color of primer, but I am pretty sure that the truck was originally white.
Does anyone have an original factory order manual with the color options listed? If you do, is there a listing for engine block colors as well? Thanks ahead of time! Rob
1966 LWB 292 I6 & Granny Low If you listen intently, you can hear a FORD rusting in the distance. My LUG NUTS take more TORQUE than your HONDA makes! |
06-22-2007, 12:30 AM | #2 |
Re: Color Combos
someone on here will get you a color chart or something.
Once you get a color idea or two or more, come on over to the photoshop forum and we can give you an idea of what it would look like. |
06-22-2007, 06:40 PM | #3 |
Rust Buster
Re: Color Combos
